seems to be a frequent problem on new coachs
I had issues with my tv. Had to slide cable in window to tv to get it to work. Found out at the antenna plate with the button it was wired wrong. Just recently figured out how to get the Jensen ceiling speakers working with the tv. Do a little tracing the wires and check the switch plate to see how it is wired. Also the hdmi cable on the tv could be in the wrong position. Antenna is off for cable but on for over the air, Also set up your tv for air or cable, Do a channel scan and it should work. The manuals suck as they give little info.
2017 Sunseeker GTS 2800 QS
2017 Jeep Grand Cherokee toad
1987 Sunstream (sold)
Retired BTC USN
Chesapeake, Virginia
