Old 11-14-2014, 03:11 PM   #1
cable tv
I have a 2014 Sun seeker 3010ds with a Jensen tv. Was using it with antenna for over the air stations, but tried to use cable for first time today and every source says no reception. I have on the of the cabinet one jack with a cable going inside to I assume the tv, and a large empty hole size of power outlet in a car. Above that is another plate with 2 Jacks and a patch cord between them. There is no manual for the TV I can find. Any suggestions?
2014 Sunseeker 3010DS
With chocolate, all is well
richardwise is offline   Reply With Quote
Old 11-14-2014, 04:01 PM   #2
TURBS's Avatar
Was your ota booster switch on?
Pictures are worth a thousand words
TURBS.
Old 11-14-2014, 04:14 PM   #3
It may be. There is a tiny green light on with an on/off push button. Wish I could post a picture but I am a bit challenged in the technical aspects of smartphones, i.e. I don't how to do it.
Old 11-14-2014, 04:19 PM   #4
GASPEDDLER's Avatar
Swithch your antenna booster off (green light off) for cable. It may also be neccesary to run a cable channel scan on your tv.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 11-14-2014, 04:56 PM   #5
TURBS's Avatar
Yep.
Green light off for cable.
TURBS.
Old 11-14-2014, 05:02 PM   #6
I made the same mistake once
Rcbstuff is offline   Reply With Quote
Old 11-14-2014, 05:05 PM   #7
Got it. Thanks everyone. I found the weather channel so I'm set. Watching TV got complicated for me when Dad put a power rotor on his antenna pole so we could get 5 rather than just 3 channels.
