Old 03-20-2019, 04:39 PM   #1
Cable tv help
Hi! We are going back to a campground that we love that has cable tv. I have a 2006 Salem 22fbs and for the life of me, canít figure out how to hook the cable up to it other than bringing it in through a window or door. There is a jack inside but I donít know where the outside connection is. Any ideas?
cmstone0718 is offline   Reply With Quote
Old 03-20-2019, 04:45 PM   #2
The one inside hooks up to your roof antenna,,,,and should have a jack outside. Is this a Travel trailer? Dont want to say its NOT cable ready. If you don't have an outside labeled jack,, It might not be.
Lee Pedrick is offline   Reply With Quote
Old 03-20-2019, 04:55 PM   #3
Oaklevel's Avatar
Not sure about your model but most of the older travel trailers and RVs were not wired for cable.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 03-20-2019, 06:01 PM   #4
bikendan's Avatar
This is true for some of the older entry level trailers, like Salem.
The outside cable connection may have been an option.
Equalizer WDH
Old 03-21-2019, 03:13 AM   #5
CincyGus's Avatar
If you do have a jack outside, connect to that and then turn the power off on the antenna booster that feeds the inside TV. It's usually a very small round button and the light on the boosters panel will turn off.
I've seen posted by many people that had tried to run the cable with the booster powered and it won't work. Turning it off evidently makes a difference.
If you don't have an outside jack, your going to have to feed in through a window or slide-out seal and directly to the TV.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 03-21-2019, 08:07 AM   #6
Most rg6 cables are round but there is a flat cable that is especially made for running under windows. Thatís the easiest fix
spock123 is offline   Reply With Quote
Old 03-21-2019, 08:30 AM   #7
bubbles's Avatar
I would search every nook and cranny including the ceiling of storage compartments primarily on the left hand side of the unit before surrendering to no coax connector for cable input.
Old 03-21-2019, 08:36 AM   #8
I suppose there are some older rigs that were not equipped with an outside port for cable TV but even our 1979 Shasta entry level TT had an outside port for CATV. Everything we've owned since then has had as well.
You could easily add one if it turns out there is none.
Days Camped: '16=46 '17=30 '18=51 '19=18
cable
