Old 08-05-2013, 03:37 PM   #1
LJ_Sha's Avatar
Cable TV hook up issue
Just hooked up at a campground and having an issue hooking up my cable TV. I've been trying for almost 2 hours. I will attempt to attach a picture. Can someone help me with how to hook it up? I've checked the owners manual with negative results. Below is what I have behind my TV. The camper is listed below
2015 Georgetown 351DS
LJ_Sha is offline   Reply With Quote
Old 08-05-2013, 04:39 PM   #2
The little black button on this:
has to be turned off (green light not on) in order for the park cable signal to be routed to your TV.
When it's on, the off-the-air antenna is connected to your TV.
Old 08-05-2013, 05:22 PM   #3
I know this sounds simple but lets cover all the bases as I am a guy and can understand the need for cable TV when its available, lol. Green light off (antenna booster) and switch to Cable, not air or antenna, in TV screen menu. Hope its something this simple and ya get it working. Hevent had a chance to use mine yet as my trailer is still fairly new and I havent had the chance to get to a park with cable. But thats how it works at home. May not have to change the TV menu at all but if turning off antenna booster (green light) dosent work, try TV menu. Thats what my Dealer told me.
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
Jandj1026 is offline   Reply With Quote
Old 08-05-2013, 05:29 PM   #4
Good point! Yes, on the TV you have to select "Cable" and rescan for TV stations.
Old 08-06-2013, 08:38 AM   #5
LJ_Sha's Avatar
Thanks. Go it working
