Old 07-26-2014, 12:42 PM   #1
Cable tv hookup at campground
I have hooked it up, done the setup option on the remote and scanned and all I get is 2 channels. Any suggestions?
ARodden is offline   Reply With Quote
Old 07-26-2014, 12:48 PM   #2
win
win's Avatar
Try turning off your boost switch on the TV antenna
win is offline   Reply With Quote
Old 07-26-2014, 12:52 PM   #3
H2oski
Ensure that the antenna booster turned off.
I'm late
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 07-26-2014, 12:54 PM   #4
camper1999's Avatar
X2 and make sure you did not hook up the cable to the satellite hook up if you have one
2011 GMC 2500HD Diesel
Old 07-26-2014, 07:58 PM   #5
Helmsey's Avatar
Has it worked in the past and is now not working or is the first time you have tried it?
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 07-26-2014, 11:05 PM   #6
robert.beck.7737's Avatar
There is a little button on the plate where you hook your tv cable to. If you push it in it will turn green. When out it is red. Try tinkering with this button. It may solve your problem.
Using Tapatalk
robert.beck.7737 is offline   Reply With Quote
Old 07-27-2014, 05:11 PM   #7
This weekend was the first time I tried. I made sure the antenna booster was off and it scanned 130+ channels and found none.
Old 07-27-2014, 05:22 PM   #8
Are you sure you were scanning cable channels and not over the air channels?
keith_h is offline   Reply With Quote
Old 07-27-2014, 05:29 PM   #9
Yes. There were 10-15 over the air channels that worked just fine.
Maybe there was a problem with the cable connection at my spot.
Old 07-27-2014, 05:37 PM   #10
Ford Idaho's Avatar
Is the CG using Direct TV?
Ask the host if your tele has the "right chip" in it.
mpg
