12-13-2017, 04:03 PM
#21
CABLE
OK folks now I'm confused. I have a 2015 Gray Wolf (just purchased used no manuals) I have a connector on the outside of the trailer labeled cable, on the inside I have 3 coax connections next to the connection for the tv to the ant. in the roof. Is this where I would hook up for cable?
Ken Powell
12-13-2017, 05:00 PM
#22
Ken Powell
Since this isn't posted in the Cherokee sub-forum, pics would help since such connections vary wildly between brands and models.
12-27-2017, 06:50 PM
#23
I'm having a similar issue with park cable.....connected the cable from pedestal to my RV; turned off antenna booster still no cable
12-27-2017, 06:56 PM
#24
Did you set the source to cable?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-27-2017, 07:00 PM
#25
... and rescan?
#26
yes...
12-27-2017, 07:03 PM
#27
On the antenna booster there is also another coax plug to add another cable?
12-27-2017, 07:05 PM
#28
yes and rescanned
12-27-2017, 07:09 PM
#29
When you ran a coax from the pedestal to your RV, were there 1, 2, 3 coax inputs?
12-27-2017, 07:15 PM
#30
Only on on the outside of rv
12-27-2017, 07:18 PM
#31
Only one? OK, mine has Sat1, Sat2 and Cable. I'm out of gas on this one. Sorry.
12-29-2017, 02:22 PM
#32
Originally Posted by Villagerjjm
You can find out a lot of information about signal quality on the link I have provided below. The Furrion televisions will pick up cable TV stations that are broadcast in "Clear QAM", but they will not be high definition. The antenna scan will pick up HD signals which the TV will display in HD formats. You can buy cable boxes that will pick up both cable and antenna. The one I bought will output digital audio, HDMI or composite. It will also record and pause live TV on a thumb drive. The only problem with any of these systems is signal quality.
https://www.hdtvsupply.com/rfcaforhdsy.html
Thank you for the info and the link. I see I am not the only one having this issue and will continue to trouble shoot before the season. Thanks,
