Old 03-26-2012, 04:32 PM   #1
cable tv problem
I have a 2012 sunseeker 3170ds. It has 3 tv's on it and I am able to receive cable tv on 2 of them but the rear bedroom will not work with cabe, However it works perfect with over air signal. Any help with where to check.
badboy267 is offline   Reply With Quote
Old 03-26-2012, 05:07 PM   #2
TURBS's Avatar
park cable may not be ran to rear bedroom only over the air cable .
Old 03-26-2012, 08:00 PM   #3
It worked,however it was a very poor picture.
Old 03-26-2012, 08:06 PM   #4
Herk7769's Avatar
Well, if you get over the air TV to all 3 TVs; then you should get cable TV to all 3 TVs.
Since you do, but one is "snowy" then I am thinking there is a high resistance (bad) splitter or cable that feeds the TV that is "snowy".
My guess is that lower channel cable comes in OK but the higher numbers are the bad ones. Higher frequencies have a hard time getting through corrosion or other high resistance connection (like a bad coil in the splitter).
I would start there. Cable connections and replace the splitter. Now, where that particular splitter is located is a mystery you will need to solve.
HAM CALLSIGN - KC3FFW
Old 03-26-2012, 08:46 PM   #5
So far I only found 1 splitter ,I will change out and see what happens. Thanks
Old 03-26-2012, 08:54 PM   #6
Herk7769's Avatar
Is the splitter a 3 way? An input and 3 outputs?
or just a 2 way. An input and 2 outputs?
The 2nd photo is a 4 way. 1 Input 4 outputs.
Old 03-26-2012, 08:57 PM   #7
Its a 2 way located under middle tv near bunk beds.
Old 03-26-2012, 09:03 PM   #8
Herk7769's Avatar
See if you can locate the coax going back the the TV that does not work well. Swap the coax with the one going to the middle TV.
If the problem moves to the middle TV; replace the splitter.
If not repair the cable ends on the cable to the rear TV.
If new cable ends do not fix the problem; replace the cable run.
Since you are getting over the air TV the TV itself has to have cable and digital tuners; so that is not the problem.
Old 03-26-2012, 09:23 PM   #9
I will try,I'll get back to you and let you know how I make out. Thanks for your help!
Old 03-28-2012, 08:20 PM   #10
Up to 2 splitters found so far, still looking.
