Old 04-19-2014, 09:02 AM   #1
Cable tv problem
2008 Georgetown se. When park cable is connected there is no signal going to either tv.If I connect it direct to tv it works fine. It has a winegard entertainment select system.There is a cable labeled Ant. and Cable and Sat,coming in at the back of unit. The Tv on ant works fine, Any one know where the other end of Sat cable might be?I was going to connect a carry out Sat system.
spidergolf1 is offline   Reply With Quote
Old 04-19-2014, 09:29 AM   #2
On the ant,cable,sat. Is there a button with a lite that is on?? If so push button till lite is off then re program tv for cable.
Jerry. Vietnam vet.
Retired
jgahlhoff is online now   Reply With Quote
Old 04-19-2014, 03:09 PM   #3
bikendan's Avatar
sounds like you left the antenna booster button on, which will not allow a cable signal.
usually is a black button with green light when on.
should only be on when using over-the-air Wineguard tv antenna.
Equalizer WDH
