07-18-2015, 06:12 PM
Who Dares, Wins
Can a digital thermostat be added to the AC unit?
More of a curiosity, but can the AC unit be retrofitted up to use the trailers heat and A/C thermostat? Out AC is a 13.5 dometic non-ducted unit with the three speeds and temp controlled by the rheostat switch on the roof.
All this talk of people in the thread about keeping their AC on while out for the day and the temp they set it at had my wondering.
2015 Chevy HD D-Max
2022 Impression 315MB
07-18-2015, 06:19 PM
Following
07-18-2015, 07:27 PM
Without extensive work, you can only use one for the heat.
Blast-from--the-Center a/c's, like yours, don't have an easy solutions to this.
That's why we made sure that our trailer had ducted a/c.
07-18-2015, 08:13 PM
We have a HW296 was hoping for options.
07-18-2015, 08:35 PM
Who Dares, Wins
Originally Posted by firedaniel
Was it a ducted AC or one like the one in our trailer?
2015 Chevy HD D-Max
07-18-2015, 08:52 PM
You can install a wireless stat
2019.5 Rockwood 2509S
07-18-2015, 09:22 PM
Do you understand the type of a/c the OP has?
07-18-2015, 09:53 PM
I've read the OP three times now and the way I read it the OP is asking IF the A/C unit can be retro-fitted:"can the AC unit be retrofitted up to use the trailers heat and A/C thermostat?" I'm wondering if "doc73" is asking about wanting to add a heat strip to his A/C.
07-18-2015, 09:59 PM
I took it to mean that the OP wants a digital stat to control the furnace AND the a/c.
07-19-2015, 09:56 AM
Who Dares, Wins
I have a digital thermostat for the heat and heat only. Ac is just a basic three speed cold and three speed fan with a basic thermostat control. Want to know if it can be changed to use a thermostat to get a better way to set a temp not just use the rheostat to get a ball park idea.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
07-19-2015, 12:01 PM
Digital thermostat...
When I had my 13,500 A/C added to my bedroom I called Advent and was told that a wall mounted thermostat could not be added. To physically compare the guts of the a/c it looks identical to a Dometic. So I would think there would be some way to do it......mine runs all the time and the compressor just comes on and off. But because of the small space, low is just too cold. I would love to have it all come on and off as needed.....
07-19-2015, 02:02 PM
As I said, I have read about someone doing this conversion, on another RV forum.
But it was extremely complicated and not cheap.
As far as I know, there is no "kit" to do this.
07-19-2015, 02:56 PM
Yes it could be done but you better have an electrical background like I do. You need to understand controls because you are going to have to disconnect all the control wiring. Then run wiring to the new stat.
I am assuming the OP does not have the background needed or he would not be asking.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
07-19-2015, 07:57 PM
Who Dares, Wins
You would be correct... No background in it. I am a quick learner and very handy but not that good!
2015 Chevy HD D-Max
07-19-2015, 09:13 PM
Many years ago I took a 4 year apprenticeship, most of which focused on control circuitry. It came in handy over the years but it is not something you can learn overnight.
Most of what I learned on was mechanical but eventually had to learn the electronics. Didn't really need it on my job with the state so stopped going to school for it about 20 years ago. Needed the mechanical side more and had to keep up with the electrical code.
If I had the drawings for that unit I could tell you how to do it but to be honest I don't think it would be worth it.
Jim
George Bernard Shaw
07-19-2015, 09:43 PM
This looks like it may be your answer:
http://www.amazon.com/Lux-Heating-Co...hermostat+cool
Super easy if your unit is plugged into a standard 120 volt receptacle. A bit harder if it is hard wired. In that case, you would have to install an plug and socket in the existing line.
07-20-2015, 09:49 AM
Nice idea but is only rated for 15 amps. This may not handle the surge from a roof top AC unit.
Jim
George Bernard Shaw
