Old 12-25-2019, 08:49 PM   #1
JWood422's Avatar
Can I add a heavier television?
I have the perfect wife. She wants a larger TV! We have an LG 32LF5600 (32Ē)that weighs 13.23 lbs. in the trailer now. We have a Sony KDL-40EX640 that weighs 25.4 lbs. that we would like to replace it with. Thatís quite the difference! Iíll have to install an adapter for the mount holes to work. My biggest concern is the weight on the wall. Iím attaching pictures to help. My trailer is a 2016 Rockwood 2703WS. The tv mount is attached to a hollow wood channel that hides the cords. Thanks and Merry Christmas!
JWood422 is offline   Reply With Quote
Old 12-26-2019, 09:07 AM   #2
Head Rambler
I'd say you'll be fine. The normal design for tv mounts in our RV's is for up to 30#.
It looks as though you could remove the mount and then remove the four 'button' screw covers and take the paneling down and see what's actually supporting the mount and then you could determine if it's substantial enough. Like I said, I bet that it is.
Gotta go campin!
Old 12-26-2019, 10:19 AM   #3
PPST Wannabe
kenandterry's Avatar
Yup. Remove the button screws covers to see what REAL strength there may be back there. Iíd want a good strong backing for the TV mount. When/if they fall......it can be me$$y.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 12-26-2019, 10:29 AM   #4
There should be a solid 2x6 behind there . that luan wouldn't even hold 13 lbs is my guess .
MR.M is offline   Reply With Quote
Old 12-26-2019, 10:39 AM   #5
As mentioned, while part of that box is hollow to hide the cords I'm betting too there is something more substantial behind there where the mounting bolts/screws attach. If so, you'll be fine with the additional weight.
If not... you better figure a way to reinforce it because it isn't even going to hold what is already there very long!
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 12-26-2019, 10:42 AM   #6
I added an articulating mount for our living room TV. I used 6x's across 2 studs and then installed the mount on the 6x's. Had it there for 3 years now and still pretty solid.
2016 26RR and a 2018 OR371MBH
mxdad is offline   Reply With Quote
Old 12-26-2019, 10:45 AM   #7
JWood422's Avatar
One thing I didnít think to mention. Itís on the rear wall. Just where the bouncing will be the worst. The other thing I sorta left out on purpose is that we just got a new 4K TV for Christmas that is much lighter. I kinda want to use it in the house. Iíve watched a little 4K content and donít see a whole lot of difference. So I may end up putting the 4K in the trailer. It just seems a shame to put the brand new TV where we wonít watch it as much. But thatís a WHOLE lot better than ruining my trailer and destroying a perfectly good TV. Thanks for your input, yíall.
Old 12-26-2019, 10:59 AM   #8
NMWildcat's Avatar
You have all kinds of options. You can beef up the mount backing plate behind that panel. You can get a lighter, bigger screen TV, you can use a mount that allows you to easily remove the TV for travel. You can install a travel support system using straps and tie down eye strap anchors (footman loops).
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 12-26-2019, 01:48 PM   #9
Maybe since you are camping you should just "rough it" with the current television?
Sorry, I couldn't resist. I'm adding a DVD player with an HDMI connection because the Jensen all-in-one low-rent system uses the poor red/white/yellow connection for the DVD side. I'd upgrade to BluRay but MY perfect wife said no way.
Having said all that, I don't think we had our television on a total of 4 hours during 14 weekends in 2019.
Dobbs is offline   Reply With Quote
Old 12-26-2019, 01:59 PM   #10
Mr. Dan's Avatar
You might have missed the most important information in the OP ==> "I have the perfect wife. She wants a larger TV!"
... but she might be interested in your use of TV statistics.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 12-26-2019, 04:14 PM   #11
Cover Dog's Avatar
Send a message via ICQ to Cover Dog
By all means get her the bigger TV, but don’t under any circumstances give her the remote !
Bill, Maura & Rosie the rescued Boston Terrier
2016 Winnebago Adventurer 38Q....26K Chassis
...traded in 2015 FR Wildcat 282RKX
2014 CR-V EX-L w/Nav & Blue Ox & Ready Brute Elite
NRA Endowment Life Member, FMCA #455593, WIT #170814 & Mid-Ohio Winnies
Cover Dog is offline   Reply With Quote
Old 12-26-2019, 06:29 PM   #12
D W
D W's Avatar
X2. Just keep in mind that the further you extend the mount the more the down force on the wall fasteners. (Reference: Archimedes Law of the Lever).
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 12-26-2019, 06:45 PM   #13
Just make sure it is secured close to the wall when traveling. You should be fine. I never understood the point of having a small TV. Bigger TVs look much better on any wall.
john221us is offline   Reply With Quote
Old 12-26-2019, 07:01 PM   #14
I had to change my mount and added a small piece of 1/2 plywood to the wall to help with the load.
Kimber45 is offline   Reply With Quote
Old 12-27-2019, 08:47 AM   #15
pburch
pburch's Avatar
I mounted a 24" x 24" 1/2" plywood to my wall and mounted a 50" TV - no problems so far
William Presley Burch Jr
Julie Ann Dyke Melbourne FL
2018 Forest River Salem Hemisphere 282RK
2018 Dodge Ram 2500 6.4 L 4 x 4 3.73 Gear 6' 4" Bed
Along with "Abby" and "Charlie" our dogs
pburch is offline   Reply With Quote
Old 12-27-2019, 12:56 PM   #16
Denver, CO
garbonz's Avatar
On a related issue, as yet unmentioned.
Most mounts already have the attachment holes that line up with all the VESA hole specs. No change in mount should be needed.
2017 Fuse 23T
Old 12-28-2019, 05:23 AM   #17
JWood422's Avatar
Except that mine donít line up. The holes in the TV are farther apart than the ones in the mount. I have adapter plates coming in today.
Old 01-02-2020, 06:47 AM   #18
JWood422's Avatar
Hereís what I ended up doing. My brother-in-law and I put the 40Ē4K TV in the trailer. The older 40Ē TV fills the space at home perfectly and is much heavier. The mount in the trailer was positioned for the 32Ē TV so the larger one extended above the cabinet over it. So I bought these wing-looking plates so I could leave the mount where it was and still mount the TV lower. It seems to be plenty sturdy. Thanks for all yíallís input!
television
