05-09-2012, 08:49 AM
can I pull the factory stereo and install a car head unit?
wondering how these stock units work?
I have a higher end car head unit that I'd like to make use of, if possible, and swap out the 4 indoor speakers to higher quality ones as well as install 2 marine speakers outdoors, selectable via a switch if so desired.
the head unit i'm looking to use has usb support and an aux in that I can use for my sirius and streaming from the internet occasionally.
is this something that is doable? or are these factory stereos only upgradable to newer models?
thanks
05-09-2012, 08:55 AM
What you seek is doable!
Be ready for the rats nest of wires behind your current unit
05-09-2012, 09:07 AM
Yes, the factory units run on 12 volts, so it can be done.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
05-09-2012, 10:14 AM
excellent. it's not so bad or a rats nest. checked up in behind there already.. out with the marrettes and crimp butt connectors and in with solder and heat shrink
05-09-2012, 12:46 PM
I did the exact same thing you want to do! I`ll get some pics of what I did. very easy to do. wired just like a car except for the rats nest of wires someone already mentioned. if you`ve wired up a car before, it`s very easy.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
05-09-2012, 02:04 PM
thanks dodge guy, my only real challenge is to mount it properly and fill that large gapping hole somehow
05-09-2012, 02:24 PM
Get ahold of trudinator on here . Her dh and her do woodworking maybe they can make you a panel that matches your wood.
They made me some stair treads for my 5er steps and there wonderful .
05-09-2012, 03:35 PM
Keep in mind that if your existing unit is also the DVD player (like many of the Concertone units), then you loose the video capability switching to an auto-style stereo.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
05-09-2012, 04:11 PM
thank you FI .. actually, mine is bare bones basic.
from googling i've come up with it as an RV2000 as pictured below
05-09-2012, 06:04 PM
most likely a better set up for a collection of wires behind the unit with your set than the factory set up. Mine was a giant mess so I used plastic speed straps to bind all the lines and vacumed out about a pound of wood chips.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
05-09-2012, 09:52 PM
that's a really old unit. what year is your RV?
05-10-2012, 06:10 AM
Can't say how old it is but they were last seen camping in the middle of the field in...
