Old 12-12-2013, 11:44 AM   #1
checca's Avatar
Lightbulb Can you add a 12v fan in the freezer to aid cooling?
Can you add a 12v fan in the freezer to aid cooling? or doesn't it make a difference?
so two questions
1. can you drill a hole into the back of the freezer compartment to get 12v to the fan? IF YES, where?
2. can you screw into the back of the freezer to mount your 12v fan? IF YES, where?
I already added a fan to the refrigerator compartment and it has worked great ... so it got my thinking.
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
Old 12-12-2013, 12:20 PM   #2
Witch Doctor's Avatar
It will not really make a difference, even if you could find one that would operate at 10 degrees or so. You probably freeze the bearings in the motor up.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 12-12-2013, 12:22 PM   #3
KMP44's Avatar
Not sure if you can (easily) do that, but in the case of the fridge fan, I think the biggest benefit is that the air circulation keeps the ice and condensation off the fins, which then allows the fridge to cool better. The increased air movement is kind of a secondary benefit as far as cooling.
In the freezer (at least in ours) there is no drain, so even if you move the air, ice crystals will still form someplace in the freezer and it will need to be defrosted. In our little freezer, everything stays frozen, just get ice buildup that has to be defrosted after a couple weeks of continuous use.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
fan
