Old 06-30-2015, 04:30 PM   #1
Cannot get to the back of my TV
We just came home with a 2015 Rockwood 2604. The TV is mounted on the wall in the living room, other side is the walk thru bath.
I need to access the back of the TV and just cannot figure out how to move it front. I slid my phone at the bottom and took some pictures. Can anyone help me? I called the dealer and they said to get to the back of the TV it would involve removing cabinetry. I just cannot believe that.
ID:	81758   Click image for larger version
ID:	81759   Click image for larger version
Missdenise is online now   Reply With Quote
Old 06-30-2015, 06:09 PM   #2
mduff's Avatar
It appears to be on a mount. Our's I can hold on the sides and pull forward which allows it to tilt and swivel. The installer may have tighten the bolts on yours to keep it firmly in place. I would try and 'gently' pull it forward.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 06-30-2015, 06:28 PM   #3
Jimandchris's Avatar
Our pdi tech mentioned that they have to be pulled firmly out. He suggested pulling from the top and bottom of the tv since it's closer to the mount instead of the sides. Good luck!
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 06-30-2015, 06:49 PM   #4
strat56's Avatar
This works on mine.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 07-01-2015, 08:32 AM   #5
What is holding the TV so firmly to the mounting? Service at the dealership states it cannot be pulled out from the wall. I just don't see how that can be. How would you re-place it if it broke, take the camper apart.
Anyone know a number I could call at Forest River/Rockwood? Do they have a tech support?
Thanks!
Old 07-01-2015, 08:41 AM   #6
They will tell you the same thing...pull hard the rubber clamps that hold it is very stiff and the swivel bolts are most likely too tight also.
2019.5 Rockwood 2509S
Toddupton is online now   Reply With Quote
Old 07-01-2015, 09:16 AM   #7
Thanks!
Can you post a pic from the side? From the top views, it sure looks like it is supposed to swivel out.
From the pics you posted, even looks like it has the rubber stop to keep it from going back to far.
Old 07-01-2015, 09:28 AM   #8
The top picture shows the plastic "clamp" that holds the tv while moving. It is a plastic half circle that the arm locks in to.
Old 07-01-2015, 09:43 AM   #9
These pics are from the bottom. I am not at the camper today, but will be tomorrow. I am not sure if I can get the phone behind the TV anywhere else but the bottom, but I will try.
Old 07-01-2015, 09:44 AM   #10
Is the plastic clamp on the right side of the top picture? I will be reaching around back there blindly.
