Old 08-06-2013, 10:44 AM   #1
Can't Find Exterior Cable TV Connection - Help
Hello all, I just purchased a 2011 Forest River Wilwood 26 RKS XL travel trailer. I cannot find where the exterior cable connection is located. The wall recepticle has a 1) Antenna cable connect, 2) "Cable" coax connected, and 3) an empty coax plug for a 2nd TV. I cannot trace the "cable" coax ... which according to the dealer is exterior cable connect line. I have searched everywhere. The orange "cable" coax line goes directly into the ceiling along with the antenna line and power. Any ideas where this ends? Also, any posibility it is in the 30 amp power cable storage bin (appears to bo no way to access this either). Thanks
Bill
Strider is offline   Reply With Quote
Old 08-06-2013, 10:52 AM   #2
larrys2112's Avatar
We have 2 Wildwood's as rentals and they both were listed as "Cable Ready" but had no external connection. We had to take care of that ourselves. We never did find the actual routing of the wires through the walls or floor of the camper. They are both stationary units now so we just routed the coax through the floor at the areas where the TV's attach. That's probably not a good option for you if you are actually travelling with the camper.
2016 Rockwood Windjammer 3008W Diamond Package
2016 Toyota Tundra Double Cab 5.7L SR5 4x4
larrys2112 is offline   Reply With Quote
Old 08-06-2013, 10:55 AM   #3
I am at home prepping for a trip but running out of time. The orange cable must run somewhere ... but without taking down the roof I can't trace it. I took out some fixtures to look but no luck.
Old 08-06-2013, 11:15 PM   #4
Call the manufacturer and ask them where the external connection is.
exterior
