Old 07-12-2015, 04:33 PM   #1
can't get signal in bedroom
We have a 2009 cedar creek 34SAT. I cannot get a tv signal in the bedroom. I have turned the switch behind the tv in the living room off, on no change. The input on the outside of the unit has two inputs, one says sat on canle hooked into both still no signal. The bedroom has two connectors mounted to the same plate. I have connected to both in all combinations with outside conections with negative results. The TV in the living room only works when the input outside is on cable. Any suggestions.
bandit819 is offline   Reply With Quote
Old 07-12-2015, 04:46 PM   #2
Georgia Frog Rally 2017
aceinspp's Avatar
So are you trying to use cable or the ant? If cable you need to set tv for cable (No ant boost) or if ant set to ant. If using ant then you need to have the ant boost on. Once selected then you need to run the search channel mod. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2015--46
Days booked for 2016--60
Days camped in 2016 so far 51
Old 07-12-2015, 04:54 PM   #3
Cable, works great in living room can't get it to work in bedroom. Have switched tvs and both work in living room only. I'm guessing there is a splitter somewhere, guess I need to start removing access panels and look for it.
Old 07-12-2015, 05:00 PM   #4
Left Coast
Start by checking bedroom wall plug for coax
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 07-13-2015, 12:22 PM   #5
dwa1000's Avatar
I had to change all settings to satellite. Then I got the bedroom to work. Not sure why.
dwa1000 is offline   Reply With Quote
Old 07-13-2015, 12:38 PM   #6
You are probably connected to the Sat connector on outside of coach or they are mislabeled.
Harkerr is offline   Reply With Quote
Old 07-13-2015, 12:42 PM   #7
Try using a splitter on the outside feed cable to both. That fix my issue.
BRUCEANDCYNDI is offline   Reply With Quote
Old 07-13-2015, 01:33 PM   #8
On my trailer,2013 8315BSS, in the cabinet, under the TV I have a box labeled Bedroom TV. I had to install a splitter off my sat. dish and works fine. The antenna has a built in splitter, but if you are using cable, or sat. you need to use a splitter to get the signal to the bedroom.
Good luck
tomrob1161 is offline   Reply With Quote
Old 07-13-2015, 01:37 PM   #9
Run a continuity test from your outside cable input to your bedroom output. No ohms? Your friendly factory assembler could of missed your complete cable connections.
ron-kanobie is offline   Reply With Quote
Old 07-13-2015, 02:01 PM   #10
My 2 week old 201SS would not produce a signal either. New TV. The tech (used loosely) connected up the Component Video cables wrong on the jack. They had the all mixed up.
2015 Nights Camped 18
2016 Nights Camped 32
2015 Palomino Solaire 201SS
2016 Ram 2500 Tradesman CTD
Leatherman is offline   Reply With Quote
bed, roo
