Old 07-31-2014, 08:57 AM   #1
DKRITTER's Avatar
Can't Rotate TV Antenna
We have a new LaCrosse 327RES and on our third trip but only first time to use the TV antenna. After we crank the antenna up I am unable to rotate it at all.
It's been raining here in Colorado and will hopefully dry out enough this afternoon so I can look at and hopefully just lube it.
Any suggestions would be appreciated before I climb up there?
DKRITTER is offline   Reply With Quote
Old 07-31-2014, 09:15 AM   #2
Just checking. You have rotated it before, correct. I ask because it does take some getting use to to rotate the antenna. It's not very intuitive in the beginning.
Old 07-31-2014, 09:56 AM   #3
DKRITTER's Avatar
This is a new trailer and it hasn't been rotated as far as I know but, we have had another trailer so we do know how to operate it. My guess is that it's just frozen and needs to be lubed.
Old 07-31-2014, 11:34 AM   #4
Helmsey's Avatar
We had the same issue on our 5er when we got it new. After getting on the roof and checking things out it turns out someone got a little dicor happy and had applied some where they shouldn't have on the antenna. A razor blade and a few minutes of my time cleaning it up and all is well now. I'd hop on the roof and see if you don't have something similar.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 07-31-2014, 12:14 PM   #5
TURBS's Avatar
You know you have to pull down the spring loaded turning knob right?
TURBS
"SABRE OWNERS UNITED"
Old 07-31-2014, 12:49 PM   #6
DKRITTER's Avatar
TURBS
Yes. This is a new trailer but we are not new to trailers.
Old 07-31-2014, 12:52 PM   #7
TURBS's Avatar
Ok just checking!
TURBS
Old 07-31-2014, 02:15 PM   #8
DKRITTER's Avatar
The dicor sounds like a pretty good culprit. I'll be sure to take a blade up with me later.
Old 07-31-2014, 03:48 PM   #9
Indymule's Avatar
My flagstaff was the same way the first time. I just kept gently rocking the knob back and forth (only moved about 1/8 inch) after a minute it popped loose and have never had a problem since.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 07-31-2014, 04:30 PM   #10
Same Problem
Same with our's when new. When you get on top you will see the "caulk" that has run over on the part that rotates. With a razor knife separate the flange from the part that rotates. Easy fix
Klemintine is offline   Reply With Quote
Old 07-31-2014, 05:24 PM   #11
raspivey's Avatar
Had that problem after ours had worked for over half a year. Looked like some of the Dicor may have balled up and got into the antenna. Couldn't move it even after cleaning and lubing it a little. Finally got my wife to hold the knob down while I manually moved it back and forth a few times. Sucker popped right out after a minute and works great now.
Old 07-31-2014, 09:02 PM   #12
DKRITTER's Avatar
Well folks we have a winner, and it was the dicor. It was very noticeable that they were very liberal with it all over the roof. it took a few seconds to cut it loose and it rotated freely.
Thanks folks
antenna
