Old 06-09-2018, 06:25 PM   #1
Cardinal 34TS mesh panel to left of Breaker box
Hello,
My wife and I just purchased a used Forest River Cardinal Model 34-TS.
We are curious about a mesh grill directly to the left of of the Electrical Breaker Panel. They is a faint odor coming from behind this grill and wondering what it is for and what might be behind it and possibly how to remove the panel\grill to access what is behind it..
Any assistance would be appreciated.
Attached photo
Thank You
Woody
Name:	FR grill.jpg
weflybye is offline   Reply With Quote
Old 06-10-2018, 08:38 AM   #2
ejohnson1144's Avatar
Ventilation for your converter maybe
ejohnson1144 is offline   Reply With Quote
Old 06-10-2018, 08:46 AM   #3
Air return for the furnace?
stephndudb is offline   Reply With Quote
Old 06-10-2018, 08:57 AM   #4
Possibly the water heater. Thatís what was behind the mesh panel on our 2004 Cardinal.
Allzright is offline   Reply With Quote
Old 06-10-2018, 10:10 AM   #5
Tombsy's Avatar
Take out a few screws and you can look behind the breaker panel.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 06-10-2018, 12:46 PM   #6
Telstar's Avatar
We have a 2005 36 TS. On ours the storage area is behind the electric panel, no screen next to it. Might be something the original owner did.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 06-10-2018, 02:20 PM   #7
On the 2013 Flagstaff FW we had, there was a sub-woofer for the sound system behind a grill similar to that. Although, there were screws so the grill could be easily removed.
AubreyE is offline   Reply With Quote
Old 06-10-2018, 02:23 PM   #8
cavie's Avatar
Originally Posted by weflybye View Post
Hello,
Attached photo
Thank You
Woody
My vote is ventilation for the converter.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 06-10-2018, 06:54 PM   #9
Thank you to everyone that replied.
It does indeed look to be the ventilation for Breaker Panel (Converter).
I pulled the converter to see if I could find the source of the smell.
The foam insulation was pushed up from around a drain pipe that occupies the same space. Suspect Mickey Mouse. He must be deceased in the hole.
We are going to check the foam under the 5th wheel and reseal above and below around the pipe to forever entomb the culprit. May he dry in peace.
Thank You
Woody and Tanna
breaker, cardinal
