Old 03-16-2013, 09:15 AM   #1
Engineer of Crazy Train
ChooChooMan74's Avatar
CaTV, OTA, and Winegard Questions
Back when I use to camp in the 90s at local race tracks, things seemed much more simple. Well, installing my Television in my Roo, I have a few questions.
First off, I had to undo what the previous owner had done. All the coax from the Winegard faceplate were removed, and he extended one of them out to where he had the TV. Opening a few cabinets, I was able to trace which went where.
I see on the winegard, there are 3 places to connect coax on the board - Antenna, Cable, and TV #2. I reconnected everything fine, with TV #2 being my primary TV because I don't want a wire exposed. Everything works great with OTA (Over the air) reception.
Now, my question is, when I hook up to park's CaTV, does the TV pick up both OTA and the CaTV signal? Does it automatically switch? Should I use the SAT cable instead with an A/B Switch? I tried looking for answers on the Winegard Site, but seems like they have a newer product out called the Sensar Pro that has a mode switch between OTA and Park Cable.
Matt
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-16-2013, 09:32 AM   #2
VinceU's Avatar
Matt
No, its manual- Connect cable to one side of A/B switch and the amplified antennae on the other side. Output to the exisiting Winn card. Switch by hand A-B and turn off amplifier when using cable. Turn on amp for Ota signal.
VinceU is online now   Reply With Quote
Old 03-16-2013, 09:54 AM   #3
I don't know why you would need an AB switch. Put the CaTV into the "cable" input on the Winegard control. When the Winegard amp is on (light) you get OTA. When it's off, you get CaTV.
If your TV doesn't have an HDMI input for the Sat receiver, you might want to use an AB switch to change the Winegard "cable" input from CaTV to Sat-receiver modulator output, but hopefully you don't have to do that.
Old 03-16-2013, 10:09 AM   #4
Great and many thanks. That is what I need to know.
Locomotive Engineer
Old 03-17-2013, 08:50 AM   #5
Herk7769's Avatar
Barry is right on.
The wall plate "button" not only routes power to the roof antenna amp; it switches between the two inputs (Antenna/Cable) at the same time.
Powered -> Roof
UNpowered -> Cable
HAM CALLSIGN - KC3FFW
