Old 04-03-2015, 09:04 AM   #1
Ceiling Fan
I have a Wildwood 40 ft park model. It came with a ceiling fan installed. The fan works fine, meaning it runs on all three speeds both forward and reverse, however, it blows the same amount of air no matter what direction or speed it's set on. Is there something I don't understand about how to operate this fan or is it just for decoration? Any thoughts?
dgking is offline   Reply With Quote
Old 04-03-2015, 09:30 AM   #2
The 3 speeds on ours is controlled by the pull chain. There should be 4 positions, off, hi, medium, low. Your switch that the pull chain connects to might be broken. Replacement can be found at Home Depot/Lowes in the ceiling fan accessory area.
Wiscampsin is online now   Reply With Quote
Old 04-03-2015, 09:38 AM   #3
Thanks for the reply but the switch is not the problem. The fan works on all three speeds both forward and reverse. The problem is it does not produce any air.
Old 04-03-2015, 09:52 AM   #4
TURBS's Avatar
Odd.
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 04-03-2015, 10:06 AM   #5
Indeed.
Old 04-03-2015, 10:11 AM   #6
Need more tilt on the blades, might be able to put more twist in the metal blade brackets.
fan
