Old 10-31-2014, 01:32 PM   #11
wmtire's Avatar
Originally Posted by rsscully View Post
Assuming you have a 30 amp service in your camper at 120 volts you have ~3600 usable watts. You could only run 2 heaters at a time on high and consume 3000 watts leaving only 600 to run everything else in your camper. Those two heaters would also have to be on separate circuits(breakers), probably 15 amp each and capable of 1800 watts per circuit. If it was a 20 amp then you would have ~2400 usable watts on that circuit. But you still have only 3600 watts available for the entire system. Drawing more watts/amps then a particular circuit is capable of will quickly overheat the wiring and trip the breaker.
disclaimer: I am not an electrician Someone else may be able to describe the situation more accurately.
Excellent post rsscully, electrician or not.
Here is the boring part, but once you understand it, then you will have a better understanding of how much stuff you can turn on at a time...either per circuit, or per total.
Watts = Voltage X amps
or another way to look at is
Amps = Watts divided by voltage
Taking what you know from the heaters tag:
Amps = 1500 watts (high setting) divided by 120 volts
So doing the math, it takes 12.5 amps to run the heater on 1500 (high) watts or 6.25 amps on the 750 (low) watts.
Most subcircuits in your travel trailers are going to be controlled by subcircuit 15 amp breakers, so you cannot exceed 15 amps per subcircuit by much if everything is correct. Depending on how your particular RV is wired, it could possibly have about all the outlets on the same subcircuit....or could have some outlets on one subcircuit and some on another.
So what this means, then EVERYTHING on that subcircuit needs to stay at/below 15 amps to keep the subcircuit breaker from tripping. You also have a master power circuit which can be 30 amps on some TT....and thus all the subcircuits added together cannot exceed 30 amps, or they trip the master 30 amp circuit breaker.
You have to practice power management, and not exceed the amps per subcircuit or master circuit. This includes televisions, microwaves, coffee pots, hair dryers, space heaters, water heater elements, air conditioners, and so forth as for anything in your RV that operates off of 120 volt power.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-31-2014, 01:41 PM   #12
Originally Posted by HONDAMAN174 View Post
Another option is to run a heavy gauge cord to the power pedestal to the 20amp plug so you can run one heater all by itself on high.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Have seen people do that. Just make sure to use a 12 ga. or heavier cord. IF you have an open spot for a circuit breaker, you could also possibly install a dedicated outlet for a 3rd leg to run a 3rd heater on.
Old 10-31-2014, 02:02 PM   #13
As we don't have any slide outs my thoughts are to install an outdoor outlet on the outside and run that to a new outlet on the inside. This would let us run the heater from the 15 amp circuit on the pedestal and leave the 30 amp circuit for everything else. It would also let us use appliances we might not normally due to concerns about overloading the 30 amp circuit.
keith_h is offline   Reply With Quote
Old 10-31-2014, 02:04 PM   #14
Angelbunnie13182's Avatar
Talking UPDATE
Looks like running 2 heaters at 750w is working. No problems. Nice and toasty in our rv. Thanks everyone for the information!
2015 Forest River Wildwood Heritage Glen Lite 356qbq
"The Pod" Aka "Place of Duty"
Visit my blog:http://www.rvlifemilitarystyle.blogspot.com
🌺 Christina LaPlaca 🌺
Angelbunnie13182 is offline   Reply With Quote
Old 10-31-2014, 02:21 PM   #15
Not to beat a dead horse- but, once again, if you'll run them on separate circuits, they will run on high. I just wouldn't recommend it for extended times or while sleeping. Plug on into a GFCI and the other into a non GFCI.
Old 10-31-2014, 02:54 PM   #16
wmtire's Avatar
Glad you got it going now. If you are interested, Forest River, INC has a list in their FAQ section of their website for some common appliance amperage draws, that also explains what happened to you with your heaters.
http://www.forestriverinc.com/FAQ/#5
Old 10-31-2014, 03:29 PM   #17
Steeljag's Avatar
Lol.....this is exactly why I'm sitting with my feet in a pool, ....in Florida!
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
heater
