Old 12-17-2017, 03:18 PM   #11
USB outlet installations
If you have limited depth for an old work box . You can use a cooper GFER extension to allow depth for the outlet device.
Name:	Cooper extension.JPG
masterglenn72 is offline   Reply With Quote
Old 12-17-2017, 03:19 PM   #12
geezer with gadgets
757Dave's Avatar
This is what we have used...
https://www.amazon.com/Decor-USB-Out...51ATJ0RF76WEJ7
Happy travels!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 5
757Dave is offline   Reply With Quote
Old 12-17-2017, 03:51 PM   #13
Multi-Slacker
You might want to look at Snappower,com. I have three of their nightlight version running in our house. I think it is close to 2 years now.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is offline   Reply With Quote
Old 12-17-2017, 07:43 PM   #14
Happy travels!
This won't work on an RV outlet, unless you've already replaced it with a home-style outlet. RV outlets are called "self-contained" outlets and have no screws on the outside to provide power. RV outlets look like this:
Name:	RV 110VAC Outlet  60880-72_white_touch_outlet_with_cover_plate.jpg
You lay the wiring inside it and when you snap on the back, internal metal prongs cut through the wiring's insulation and make the electrical connection. Because it's all internal, there is no normal electrical box. They are fast and easy for the manufacturers to install.
That's why if you want to use normal house-style outlet with USB ports, which has screws for the wiring, you need to install an electrical box to protect the screws from shorting on something.
UPDATE:
After some searching I THINK i've found a self-contained outlet with USB. See here, pg 7:
http://www.hubbell-wirecon.com/liter...on_catalog.pdf
Not sure where you'd buy them, though.
Don't let the special tool scare you off. You can start each wire individually by just pushing them down on the prongs with a screwdriver, than put the back on, put a block on wood on each side, and use a C-clamp to squeeze them together.
UPDATE UPDATE:
Here's a video of a guy tapping into the self-contained outlet under his dinette and routing power to a 2nd USB outlet installed in an electrical box. He COULD have simply installed the electrical box and USB outlet in place of the original self-contained outlet, but I'm guessing he wanted his USB outlet closer to the aisle (I'm guessing because I only "spot-watched" the video, as I've already done something similar, but with a regular duplex outlet, not a USB one.)
2011 Traverse LT, 3.6L, FWD
Old 12-17-2017, 08:41 PM   #15
I don't know much about RV electricity, but I'm wondering if this would work?
Snappower.com has an outlet cover that converts a regular outlet to a USB charger plus outlet, just by replacing the plastic cover.
I ordered a few, but they are still in transit so I don't know how they will work in an RV.
damann is offline   Reply With Quote
Old 12-17-2017, 08:49 PM   #16
If they're like the ones in Post #12, they won't work. See why in post #13.
Old 12-17-2017, 09:25 PM   #17
geezer with gadgets
757Dave's Avatar
Rockfordroo, you are correct, sir! The outlet was one that the previous owner had put in our MH. Didn't know that the original outlets were different. Thanks for pointing this out!
Old 12-17-2017, 11:23 PM   #18
i did this in my 2014 georgetown xl. the outside wall are abou 1-1/2" thick. the recp I bought from amazon was too big, so I madea 1/2' spacer from wood and painted it black. the couch uses 12 gauge wire so it is very stiff, so make sure screws are tight.
jrowe0521 is offline   Reply With Quote
Old 12-19-2017, 10:47 AM   #19
Chuck.C's Avatar
Whatever receptacle or external plug you use, be sure it has plenty of amperage. I used this one for my RV and it supports 2 USB cables at fast charge. Internal chip controls charge rate.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This one has 3.6 amps to the USB ports.
The other thing to look for is the placement of the various plugs. Some are set up so you can't use both 3-prong and USB simultaneously.
2013 Coachmen Mirada 35DL
Chuck, Susan, and dogs- Gracie the Registered SnackHound and Toby the Wonder Boxer
Chuck.C is offline   Reply With Quote
electric, electrical
