Old 03-15-2012, 08:23 AM   #1
crs76's Avatar
Changing thermostat-Any tips ?
I have been reading on here and it seems like the problem I have is the thermostat. It wont shut off when reaches temp or have to move the selector a few time to get it to come on.
Its a Duotherm with the pop off face. I picked up a honeywell looks to have all the same features except digital readout.
Hope to be able to fix it myself, any tips ? Do's Dont's ??
Thanks in advance.
crs76 is offline   Reply With Quote
Old 03-15-2012, 08:42 AM   #2
Couple of links for you to read.
Hunter Thermostat
RV.Net Open Roads Forum: Therostat upgrade to digital Honeywell RTH111 /RTH221
Old 03-15-2012, 12:33 PM   #3
crs76's Avatar
Sweet !! Thanks Wiscampsin, going to give it a shot.
Old 03-24-2012, 07:24 PM   #4
B47
Thanks in advance.
CRS - One problem people think they have with any thermostat is that they often do not give the thermostat enough time to response to the settings. Often they will move the thermostat to a new ON or OFF setting and expect the furnace to immediately turn on or off. The thermostat needs a little time to "adjust" to the new setting.
Try waiting a few minutes after adjusting the thermostat to see if it turns the unit either on or off.
Old 03-26-2012, 08:02 AM   #5
crs76's Avatar
Mine was toast. It would not shut off at all. I installed the honeywell and the heat and air works great and its a digital readout. Just dont know where to hook up the fan ?
There is one extra wire ?
Old 04-09-2012, 11:18 AM   #6
I also installed a Honeywell unit and am glad I did. My original t'stat had six (6) wires and the new unit used only four (4) wires. As best I remember I DID NOT use the blue or brown wires with the new thermostat. I have only one fan speed so I selected the "LOW" speed and it works just fine.
Thurman is offline   Reply With Quote
Old 04-09-2012, 10:56 PM   #7
opcop's Avatar
Try this old thread. It helped me out.
My First Mod to 831KRSS
The Wilson's
1994 Chevy 1500 Chevy Suburban, Equalizer hitch, 2007 Rockwood 8315SS
My photo albums: http://www.forestriverforums.com/for...bum.php?u=3937
opcop is offline   Reply With Quote
