06-03-2017, 07:41 PM
Check light on Refrigerator
Just noticed that the check light is on on my refrigerator is on.... Running on AC and working fine .. Any suggestions?
06-03-2017, 07:45 PM
Check lights are usually associated with the fridge being on gas and there is no gas getting to fridge, or at least not igniting.
Are you sure the gas button is not on?
If it's not, I'd look up the manual for your model of fridge and check it out.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-03-2017, 08:18 PM
I had just turned the gas on to turn on the water heater... Once we all took showers and turned the gas off the light went off ... I'm new to RVs.. Even tho the fridge is running onAC should I leave the gas on also?
06-03-2017, 08:25 PM
If your fridge has an auto button, use that so it will run on electric when available, and switch to gas when not. The check light should only come on when 110 electric is not available and the gas is off. I would check the settings on the fridge. Auto is the way to go.
We leave our propane on whenever we use the RV.
06-03-2017, 09:07 PM
Retired and Loving Life!
[QUOTE=Bigblueoval;1524063]I had just turned the gas on to turn on the water heater... Once we all took showers and turned the gas off the light went off ... I'm new to RVs.. Even tho the fridge is running onAC should I leave the gas on
We leave the gas on and have the refrigerator set to "auto" and run the water heater on electric when connected to shore power. Only use the gas for the stove and burners. With the refrigerator set to auto, it will default to electric when you have shore power.
06-04-2017, 06:31 AM
Insert witty title here
When the fridge is set to auto and connected to shore power, the check light will come on when there is no propane reaching the fridge. If this light turns on, I know my propane tank is empty and it's time to switch to the other.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
06-04-2017, 08:41 PM
Just a quick thought, if I recall correctly, a fellow camper near us recently had their check light come on after having to remove the frig. to fix a loose wire. We traced it back to a blown 12 volt fuse to the refrigerator. The light was on when in auto mode and running on AC, if I am recalling right. Might be worth a quick look in the fuse block to make sure. Good luck.
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
06-04-2017, 08:52 PM
In my sunseeker, the check light means it tried 3 times to fire up on propane and failed. Remedy - turn the fridge to off then back on again. If it still comes on then check further on the propane lighting issue. It has come on several times while I am on the road and always responded after reset.
2016 Sunseeker 2400WM Sprinter 3500 Diesel
06-04-2017, 10:50 PM
I agree with TryingToLearn on the check light coming on when refrigerator is not getting gas. On all the campers that we've owned, the stove has been beyond the frig, from the propane tanks, and I always make sure gas is to stove and a burner will light first, then the refrigerator will usually light on gas the first time. But before my neighbors problem with the 12 volt supply to his, the blown fuse, I didn't know the check light would come on also. Not sure if all models and makes of refrigerators do this, just my observation.
Tony & Brenda
Happy Camping!
06-05-2017, 12:19 AM
This is a bit off topic, but I'm lost. I have a fridge question. I shut down our RV for the summer, disconnected the electric, and left fridge door open to air out. I left the auto button on by mistake. Question is, "Will the gas side keep trying to ignite to startup fridge?"
06-05-2017, 12:24 AM
Just as confused as you
I am a seasonal on a permanent site. I leave the refer on auto with both LP tanks open. If the campground looses power then the refer switches to LP. It switches back to AC when power is restored. Water heater is on LP only. I do have electric element but I don't use it. I've had to refill each tank only once each season in the 9 years I've had a TT.
Larry Tiner, yes as long as you have the battery disconnect turned on. I take my battery out and bring it home at the end on season.
Richard & Jill
06-05-2017, 12:31 AM
Thanks, Scrapper. Guess I'll make a road trip tomorrow, darn!
06-05-2017, 02:55 PM
Took the road trip, Scrapper. My battery disconnect was turned off, so I was okay. I still turned the fridge off. Thanks for the info.
06-05-2017, 03:00 PM
While it may not be germane to this discussion, my 'check' light on my Suburban 3 way fridge always glows slightly when the fridge is operating, always has and I ignore it.
06-05-2017, 03:07 PM
The answer is "no" after 3 failed start attempts; just like the water heater and furnace.
This is a safety feature so propane does not fill up the compartment; then a random spark cause a "boom".
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
