Old 08-12-2018, 05:44 PM   #1
Check you AM/FM antenna
We are setting up our 2016 Wildcat 28SGX to use as little power as possible when boondocking.
One of the items on my list was to put a toggle switch on the factory AM/FM radio so we could put it to cold iron. In the off mode it works as a clock. However it is mounted beneath the kitchen counter and is really too low for that purpose. Also the light it puts out a night is a distraction.
While I was under the counter sorting the wire out I found one bundle of wires tightly coiled and zip tied. Cutting it loose I found it was the antenna for the radio. The radio has never performed well when remote but we didn't think anything about it since we use the BlueTooth ability to play off of our phones.
I clipped the zip ties off and spread the two beam wires out as far as practical under the sink area.
If you're having issues with radio reception, you may want to check the antenna.
Parrott_head is offline   Reply With Quote
Old 08-12-2018, 05:49 PM   #2
Denver To Yuma In 90 Days
You should be able to just take the face plate off of the stereo to cut total power to the radio.
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote
Old 08-12-2018, 05:51 PM   #3
I don't think ours is detachable and a toggle switch is easy enough and I can't loose it....or drop it..
Old 08-12-2018, 06:10 PM   #4
What brand stereo is it?
If it is a Furrion that looks like a standard car stereo, then it most likely does come off.
Old 08-12-2018, 06:12 PM   #5
Not sure what brand, we seldom use it.
Old 08-12-2018, 06:14 PM   #6
AFAIK, my Furrion radio uses the television antenna. If I turn on the tv antenna booster, I get fair FM. Sucky without the boost.
2019 Cherokee Wolf Pup 16BHS
currently towed with 2008 Ford Exploder w/tow package
Husky Centerline TS WDH 400-600# rated bars
2018 camped 16 nights at 4 GGs.
Boomerweps is offline   Reply With Quote
Old 08-12-2018, 06:17 PM   #7
Mine was also hooked up that way...and was shorting out my TV antenna and cable signal input to the living room TV.
Get an outside mount AM/FM antenna...you'll be much happier, and I'll be you will get a better picture on your TV, too!
Old 08-13-2018, 01:46 PM   #8
A bundle if wires around an antenna cable?@?!?!
This is a no no especially if any of them have DC or AC power through them. Not for safety, no problem there... but the interference, cross talk, signal degradation can be anything.
Glad you separated the copper signal blockers.
And yes whatever brilliant engineer or designer had any antenna placed on the side of a camper should be put on the scrap pick up line.
rlh1957 is offline   Reply With Quote
Old 08-13-2018, 03:16 PM   #9
I have a FR Puma 23FB with an iRV Technologies combination radio/DVD player. The radio does draw a slight voltage even when off for both the clock and memory for tuned stations, etc.
My radio does not use the Winegard crank up TV antenna. It has its own chrome wire antenna on a flexible spring. The wire antenna is about 15 inches high and doesn't need to be raised or lowered. Top of the antenna is slightly above the top of the AC. Depending on signal strength is my determining factor.
johng4706 is offline   Reply With Quote
Old 08-13-2018, 03:21 PM   #10
Iwannacamp's Avatar
Hmmmm. Cool and thanks for that. It does look like an auto radio. I will check her out.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
antenna, check
