Old 05-22-2013, 09:11 PM   #1
OL Creeker's Avatar
Checking pedestal power
Do any of you check the pedestals for proper power before hooking up?
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 05-22-2013, 09:17 PM   #2
wmtire's Avatar
Yep, every time now. Haven't ran into a problem yet, but it's that one time I am trying to prevent by checking.
I did run into a loose/worn 30 amp outlet, but that didn't show up in the testing phase.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-22-2013, 09:20 PM   #3
My Progressive Industries EMS-HW50C unit does that for me (and more).
Old 05-22-2013, 09:25 PM   #4
Twisty's Avatar
I use one of these
Portable 30-amp Surge Protector with Voltage Protection - Progressive EMS-PT30C - Surge Protectors - Camping World
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-22-2013, 09:28 PM   #5
Herk7769's Avatar
Before I got my Franks Autotransformer, I checked it manually every time.
Here are some things I found.
ID:	31147   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-22-2013, 09:40 PM   #6
OL Creeker's Avatar
Thank you! We've ordered a CC and want to ensure we're safe, electrically. It seems there is more to be concerned with when using 50 amp.
Duramax/Allison
Old 05-22-2013, 10:29 PM   #7
Herk7769's Avatar
I think there have been more 30 amp campers ruined by mis-wired pedestals than 50 amp campers. Having said that; 50 amp pedestals come with their own set of troubles.
Old 05-23-2013, 07:57 AM   #8
Yea, I don't really think there is that much unique for 50-amp. The only additional thing that needs to be checked is that there is 240v between the two hot lines (when plugged into 50-amp service).
Old 05-23-2013, 08:12 AM   #9
Wanna Be Camper
SaskCampers's Avatar
Same here except mine is the HW30C. It sure is nice to just plug in and then have a look at the monitor in the trailer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 05-23-2013, 09:17 AM   #10
Herk7769's Avatar
Believe it or not; the most common problem with 50 amp pedestals is an open neutral. All 50 amp services should have 220 VAC between the hots; but the camper requires the neutral for the 110 volt items on both phases in the camper's power center.
Without the pedestal neutral (corroded, loose, or broken), the camper's neutral bar becomes a conduit for the hots to cross over to the other phase providing 220 volts across the camper. (this is bad).
