Old 11-19-2019, 04:40 PM   #1
Coax connection NOT working
I wanted to see if anyone knows where the primary coax connection from the outside hits a splitter inside the motorhome? We tried to connect to coax cable over the weekend and when I connected it to the panel port and scanned for channels none were found. When I connected the cable directly into the back of the TV and re scanned everything showed up.
Thanks in advance
With the Winns is offline   Reply With Quote
Old 11-19-2019, 04:44 PM   #2
Mr. Dan's Avatar
Thanks in advance
Do you mean "Coax connection NOT working"?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 11-19-2019, 04:45 PM   #3
Yes, it's NOT working.
Thank you for catching that
Old 11-19-2019, 04:46 PM   #4
Mr. Dan's Avatar
Fixed
Old 11-19-2019, 04:50 PM   #5
D W
D W's Avatar
Thanks in advance
Have you made sure that the OTA amplifier button on the wall plate is in the "OFF" position ?
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 11-19-2019, 04:52 PM   #6
I did, and i made sure that the tv scanned for Cable with no luck. Like i mentioned, when I connected it directly into the outside TV i was able to pull over 50 cable stations.
Not sure if there is a cable routing schematic for the rig, or if this is something that the dealer needs to do.
Old 11-19-2019, 05:11 PM   #7
D W
D W's Avatar
Unfortunately, cable schematics for these rigs rarely exist. Which type of wall plate do you have?
2016 Salem 27RKSS
Old 11-19-2019, 05:21 PM   #8
Head Rambler
If you have both cable and sat connectors on the outside of the RV, just connect the park cable to the Sat connector and switch the tv coax to the Sat connector on the inside.
Gotta go campin!
Old 11-19-2019, 05:33 PM   #9
Just to add my two cents,,I found mine behind the radio in my travel trailer and they could also be behind the wall plate that has the amplifier button on it. I did hear a horror story of one being buried in a wall nowhere near any access point. If you know an electrician, there are tools that can trace wires buried in walls and you can trace their path. WE HAVE THE TECHNOLOGY!!
TT: 2018 Coachmen Catalina
243rbs(rear bath) legacy edition
TV: 2017 Ram 1500
Lee Pedrick is offline   Reply With Quote
Old 11-19-2019, 05:44 PM   #10
D W
D W's Avatar
X2. That is exactly what I was going to suggest if the OP replied back that he had the 7542 wall plate. That is the way mine works.
2016 Salem 27RKSS
Old 11-19-2019, 07:47 PM   #11
NXR
NXR's Avatar
I see you have a 2019 but I do not see the model of your motorhome.
Our Georgetown GT5 has a switch box in a cabinet over the TV but you can't see it unless you're over 6' tall. It has a slide switch on it for Antenna/Cable/Satellite.
Do you have such a switch? If you don't know, that's what I'd go hunting for.
Ray
Name:	TV Switch Box.PNG
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 11-21-2019, 09:04 PM   #12
I had same problem and found a loose connection behind the outside connection. It was also wired wrong. They swapped cable connections behind the panel. Never did find the splitter. Bama Rambler found the same solution I ended up with. Works like a charm.
Grumpy7159 is offline   Reply With Quote
Old 11-21-2019, 09:41 PM   #13
Newbie- 21 FBRS
We tried to use Cable Tv for the first time today. Used OTA previously. No channels on the cable connection. I swapped as you indicated and all 32 advertised channels were there. Now, WHY does the cable connection not work? Is it just cabled incorrectly?
Coevers is offline   Reply With Quote
Old 11-21-2019, 09:55 PM   #14
bikendan's Avatar
Did you turn the OTA booster switch off?
Equalizer WDH
Old 11-22-2019, 07:35 AM   #15
Head Rambler
The 'Cable' input usually runs through a splitter and a lot of times it's hidden in the wall or elsewhere, and a lot of times they're not wired correctly, or they have bad connection(s). It's usually easier to just swap to the 'Sat' connector than to try and chase down the 'Cable' issue.
Also, the Sat coax is a straight run (no splices, etc.) between the outside and inside F-connectors.
Gotta go campin!
Old 11-22-2019, 07:58 AM   #16
bubbles's Avatar
Yes but that splitter is typically the booster on/off plate (Winegard panel) where one of the plate outputs is for the main tv and one output is for a second tv and that output could go to a splitter for more than one other tv. This arrangement is why the booster must be selected off for cable viewing.
Old 11-22-2019, 08:54 AM   #17
Newbie- 21 FBRS
I did- I had seen your comment also on this thread. I scanned cable both on/off and scanned AIR. As well. Only one channel where we are camping.
Old 11-22-2019, 08:58 AM   #18
Newbie- 21 FBRS
I must have an incorrectly wired connection. I got no signal at all on the cable connection, but worked fine on SAT. Thanks!
Old 11-22-2019, 09:15 AM   #19
Not uncommon and there have been many reports here of such.
You can start by removing the wall plate and looking at the connections. Also, often times there are splitters shoved back in the hole where the wall plate attaches.
You could have a bad connection, a bad cable, a staple/screw/nail through a cable, etc.
Days Camped: '16=46 '17=30 '18=51 '19=53
