Old 10-26-2013, 10:39 AM   #1
Coax Plug
Just purchased a 2008 Ultra-Lite 5th wheel. It has a coax connector just outside the window on the slide side. Previous owner know nothing about it. Looks like maybe a factory item. Anyone seen this before??
cadman99 is offline   Reply With Quote
Old 10-26-2013, 10:46 AM   #2
Ford Idaho's Avatar
Satellite I'd bet.
Roof or tripod mounted.
Old 10-26-2013, 11:01 AM   #3
That looks like a flat - ribbon coax. Probably your external park cable hook-up. Do you have external park cable hook-up anywhere else ... if not this is probably it, rigged this way because it was not installed to begin with ... could also be similar satellite hook-up
Strider is offline   Reply With Quote
Old 10-26-2013, 11:05 AM   #4
There are already external coax hookups. Because this was installed in the slide side I assumed it was factory. No visible wires inside and it would be quite a chore to install as aftermarket.
Old 10-26-2013, 11:10 AM   #5
Ford Idaho's Avatar
What is in the slide a table or a couch?
Old 10-26-2013, 11:27 AM   #6
Herk7769's Avatar
This is a window connector used specifically for antenna cables like WiFi or Cell Phone Boosters. I use the same one in my camper.
Here is where you can buy one. Eagle Aspen FC-300LX Slimline Flexible 8 Inch Flat RG6 Coax Window Cable (FC-300LX) from Solid Signal)
HAM CALLSIGN - KC3FFW
Old 10-26-2013, 12:29 PM   #7
It's a large slide - both table and couch - this is on the front end near the table.
Old 10-26-2013, 12:47 PM   #8
Ford Idaho's Avatar
Ah, could have been a work station setup.
The people you got it from are they the original owners?
Old 10-26-2013, 04:53 PM   #9
Yup - original owners - but not to RV or mechanical savvy so I am sure they didn't do it. I just thought someone else might have it on theirs. I will nave to remove the radio panel to see what it is.
