Old 10-05-2012, 12:33 PM   #1
rosebunch's Avatar
Unhappy Columbus 295RL dissapointmen entertainment center
Hi all,
I have run into a dilemma with my new 295RL, I purchased a Dish receiver to use while camping. The way the entertainment center is designed, I can find no possible way to set the satellite receiver any where in the center. It wont fit in with the surround sound, or in the cabinet above and I cannot get it to fit behind the tv itself. Has anyone run into this before. Any viable solutions found?
Appreciate any input/advice you might have
2013 Columbus 295RL
now 2010 RAM 3500 Diesel Crew Cab Laramie
killed by drunk driver1995 Dodge Cummins Exhaust Pac brake, DTT trans, cold air intake mods, TST #5 cam plate & others.
Pull-Rite Super 5 15.5K hitch
Been trailering since 1977
rosebunch is offline   Reply With Quote
Old 10-05-2012, 02:25 PM   #2
TURBS's Avatar
Originally Posted by rosebunch
Hi all,
I put mine in the basement of my 5er out of the way.
No room by tv either.
Turbs
Old 10-06-2012, 05:14 AM   #3
Trailer Trash
295RL has the tv area tucked into a corner like it was a plan b afterthought. Can the dish reciever fit into the two cabinets up by ceiling?
320RS has the tv area as a main central theme of the living room so there is lots of areas one could put the dish reciever. IF the receiver is skinny enough, it would fit in the black glass door above the tv. Lots of free room on the right. The left has the dvd player/home theatre box.
Be advised there is not much for extra wiring (service loop) to move home theatre box to see back side of it - can only turn mine about 90į to work on it.
joelek is offline   Reply With Quote
Old 10-06-2012, 09:59 AM   #4
rosebunch's Avatar
Thanks JOELEK,
Your picture of the 295RL is exactly what I have, the dish receiver is to large for the upper cabinet or behind the glass door. My old DP311 receiver would fit behind the TV but the VIP211K for HD tv is a little to tall to fit under the TV. It is also an inch wider and deeper. Not sure if it would fit even if it was not to tall to go under TV. The only way I can try it for sure is to remove the top swivel mount for the TV and slide it over top and down behind. Have not tried this yet.
Of course another problem has developed as the satellite connection does not work in the RV. The connection is broken some where between inside port and outside port
2013 Columbus 295RL
Old 10-06-2012, 10:31 AM   #5
Trailer Trash
I've read a few messages on here about the sattellite and cable coax terminals being bad on Columbus RV's They need to be crimp on style vs cheap screw on style. Never tried mine as I don't watch satellite TV. DVD and Antenna TV is how I roll.
I suspect reciver box for non HD or non DVR would be smaller than what the unit you mentioned They are pretty small on DirecTV units. However, the HD DVR box is much larger. You may want to try a non DVR box that is HD and see if that would fit behind the small black glass door. Then go with a 3rd party DVR recoder and locate the recorder in the upper cabinet.
Old 10-06-2012, 02:17 PM   #6
rosebunch's Avatar
Jolek,
My VIP211k is a non DVR solo receiver. Yes it is smaller than the 722K DVR I have in the house. The corner unit is much smaller with the 90 degree angle within the cabinet. Not much room for anything in there.
2013 Columbus 295RL
Old 10-06-2012, 02:49 PM   #7
Trailer Trash
Bummer Rose. On the 320RS when you open up the skinny black glass door, about 1/2 of the shelf space is empty in there. Lots of room on the right for an add on device.
Is it side to side width, front to back depth, or top to bottom height that is your limiting factor? Im guessing front to back depth as the pictures above show width of tv, glass door and 2 cabinets to be the same on 295RL and 320RS. The V shaped cabinet must limit side to side width so only one device fits within the glass door.
Maybe you can cut out the middle divider in the 2 upper cabinets and put your reciever up there. Have to open the doors to use it of course.
Old 10-06-2012, 07:05 PM   #8
rosebunch's Avatar
I have considered taking out the middle section on the upper doors, I would probably have to remove the doors and put a deeper shelf up there as the V shape in the back makes the usable space to narrow for the depth of the receiver. It is a very impractical setup but will have to figure out something. For now I have set a small folding table next to the fireplace and dinning table. Placed the receiver there but of course must move it for travel.
2013 Columbus 295RL
Old 10-06-2012, 09:59 PM   #9
Industrial grade Velcro. Mount to the wall or back of tv. If your remote is RF, then location of the box doesn't matter.
crasher is offline   Reply With Quote
Old 10-07-2012, 08:40 AM   #10
Trailer Trash
Mount under the cabinet/above the tv or if wall will support it, to the right of TV via a shelf fastened to wall. Those 3M Command series pull to release gizmos work GREAT as an alternative to drilling holes into walls.
Command
