Old 07-06-2015, 12:49 PM   #1
KarenDLS's Avatar
Command center not working
We have 2012 Sandpiper 346RET and the awning, slides or level legs only work on the remote not the command center or switches outside for legs. Help please. Is there a reset switch somewhere? Power is to the command center. The light switches work the H2O, and holding tanks read out with their red lights. Thank you for any help.
KarenDLS is offline   Reply With Quote
Old 07-24-2015, 10:44 AM   #2
KarenDLS's Avatar
Okay Since I got no answers to my problem. I will post solution for anyone else that might have this problem. In my 2012 Sandpiper 346ret the module (brain center) for using the remote to move slideouts, awning, landing gear, etc. is located inside the lower cabinet under the command center panel. Remove two screws and take off the cover. There is a green wire that has an inline fuse. If that fuse is blown you can not use the command center switches to move slides or landing gear. Replace the fuse and you can again use either the remote or command center.
