Closed Thread
Old 08-02-2008, 03:26 AM   #141
Just took delivery of my 2008 Flagstaff 831KRSS and all works ok except the XM connection. I have an XM roady unit that fits into the dock and powers up but no sound through the system. As for the rest, we'll see how it looks after hitting the road
doktirbob is offline
Old 08-02-2008, 07:13 AM   #142
We have a 08 2701SS and the XM radio is set to run on Input 1 while the TV is on Input 2. Just change the input using the function button. Our XM puts our a low volume so we need to crank up the volume on the Concertone. (We have an older XM Roady in the car and I can adjust the output volume to match the input on the car's audio unit. I have not found this option on the setup menus on current Roady in the trailer. Maybe I should crack open the manual. 8-)
Ron
Biker_Ron is offline
Old 08-05-2008, 02:54 PM   #143
I have a new zx600 in my Rockwood, but now anytime you disconnect from 110V power to RV then hook back up, you have to pull fuse on radio for a few seconds then reinstall before unit will work. Any ideas?
Nitroboat is offline
Old 10-13-2008, 06:35 AM   #144
well i can say that we went through the entire summer and the last concertone has worked flawlessly. not one complaint. the last unit i received was supposed to be a "new" unit made by a different suppiler for the internal parts. my dealer received ten of these units after we rattled the vice pres. chain at rockwood. we talked to him on his cell phone while he was driving home. we had action from concterone in 10min. hope everyone else has good luck.
skidoonut is offline
Old 10-19-2008, 01:00 AM   #145
CampeRooo
rthrbelsewhere's Avatar
For anyone looking for their contact information...
http://concertone.com/index.html
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline
Old 02-11-2009, 08:16 PM   #146
Brand new ZX6000. 'Load' stays on. I can't power the unit off or use any function at all. Any ideas ???
p598738 is offline
Old 02-12-2009, 05:39 AM   #147
Commercial Member
huntr70's Avatar
Pull it out, pull the fuse, unplug it, then wait about a minute. Put everything back together. There supposedly is a reset procedure.....
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline
Old 02-24-2009, 05:45 PM   #148
Hoe do I get a ZX600 out ?
911phoneman is offline
Old 03-04-2009, 12:50 PM   #149
There is a plastic ring / cover around the outsdie of the unit hiding 12(?) screws. Pull the plate and screws and welcome to the world of bad wiring!
JJMorrocco is offline
Old 03-05-2009, 09:11 PM   #150
I went to the storage facility today to work on my RX6000 based upon the advice I've received here. I turn on the rig and push the RX6000 on button. Darned if it didn't come on. I pushed reject and the CD came out !!! I tested all the functions and they all worked.
In summary, it stopped working for no reason and now it works for no reason !!!
Very very odd.
p598738 is offline
Closed Thread
