Old 05-12-2014, 09:11 AM   #11
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
flyguy, The zx400 was an old model when I had joined the company so I was not super familiar with it. Sorry I cannot help with that. :-(
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 05-12-2014, 09:18 AM   #12
flyguy's Avatar
That's OK Bob, I'm glad to see that your still available for comment.
2003 Wildcat 27RL
2008 Toyota Tundra 5.7L Crewmax
Superglide 3100 Autoslider Hitch
Timbren SES
Prodigy P3 brake controller
flyguy is offline   Reply With Quote
Old 05-12-2014, 05:06 PM   #13
Thank you bob I appreciate it very much,and all that had input,thank you too.
Happy camping
dtb7811 is offline   Reply With Quote
Old 07-26-2014, 11:15 PM   #14
Thanks!!!
Originally Posted by dieselbobcat View Post
The Concertone in our previous Roo23SS acted similar. It was DOA with the red light on... Solution was to remove the 12V power supply from the head unit and let is discharge any voltage. From what was explained to me, low voltage or the temporary flicker of voltage from the converter when plugging in can cause these units to hang up. I had to "reset" ours a handful of times over the four seasons we owned it.
As a easier fix, I added a momentary (NC) switch to the cabinet panel near the unit... of course since there was a easy method to reset - it never hung up again.
IIRC there are two snap on plastic endcaps, there are four square drive screws below that hold the unit. It is smaller than you would think once you remove it.
Hope this might solve your issue.
This resolved my issue. I had disconnected shore power, and then the 12V battery. After hooking everything back up, just the power light on the ZX400 Concertone. All I had to do was remove a panel from behind the unit, disconnect the 12 V connector (2 pin black and red wires), reconnect, and presto!!!
June 2014 to present:
2011 Salem Villa Estate 392FBRB2Q
July 2012 to June 2014:
2006 Keystone Hornet 31FLS
KyleB is offline   Reply With Quote
concertone
