Old 05-10-2014, 06:03 PM   #1
Concertone help
I have a zx75 should this unit be able to operate on 12volt (battery)?
It will only work when I'm plugged into 120v.
On 12volt power only,just the power light is on but unit will not turn on,anyone have any idea's?
dtb7811 is offline   Reply With Quote
Old 05-10-2014, 06:12 PM   #2
Witch Doctor's Avatar
All concertones are 12v, you can try and do a reset. This is a dumb question, but you are pushing that red button to turn it on correct? The radio is wired hot for the memory.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-10-2014, 06:18 PM   #3
Yes.but why would it work fine when plugged into 120v.
On 12volt just the power button is lit,won't turn on.
Without me digging out my Manual and me not being in front of it right now,do you know this procedure by chance.(boston bruins are on.)
Old 05-10-2014, 06:47 PM   #4
Iggy's Avatar
Bob Fields who is a Forum member may be able to assist. He works for Concertone.
His forum handle is Bob Fields.
I just sent Bob a message to come here and help you.
Just wait a few.
2012 Georgetown XL - 378TS 63K + miles
Iggy is online now   Reply With Quote
Old 05-10-2014, 06:52 PM   #5
Thank you very much(bruins winning 1-0)
Old 05-10-2014, 10:31 PM   #6
bikendan's Avatar
Bob Fields has not worked for Concertone for at least a year now.
Equalizer WDH
Old 05-11-2014, 06:49 AM   #7
dieselbobcat's Avatar
The Concertone in our previous Roo23SS acted similar. It was DOA with the red light on... Solution was to remove the 12V power supply from the head unit and let is discharge any voltage. From what was explained to me, low voltage or the temporary flicker of voltage from the converter when plugging in can cause these units to hang up. I had to "reset" ours a handful of times over the four seasons we owned it.
As a easier fix, I added a momentary (NC) switch to the cabinet panel near the unit... of course since there was a easy method to reset - it never hung up again.
IIRC there are two snap on plastic endcaps, there are four square drive screws below that hold the unit. It is smaller than you would think once you remove it.
Hope this might solve your issue.
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 05-11-2014, 07:03 AM   #8
Thanks for the info.
Old 05-12-2014, 08:03 AM   #9
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
dtb7811,
Sorry to hear you are having issues.
I don't recall the issue dieselbobcat mentions above affecting the ZX75. Your issue sounds like you might have a bad ground as the unit is not powering up on 12Volt only. I would check all your grounds from the battery, to chassis to behind the radio. On 120V the converter is putting out enough juice to overcome or bypass the issue. Thats where I would start.
Also bikendan is correct, I no longer work with Concertone, but happy to help out where I can. Just remember I am a forum member, not a supplier employee! :-)
Happy camping!
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 05-12-2014, 08:48 AM   #10
flyguy's Avatar
Bob Fields, I have the ZX400 in my Wildcat, I have noticed that the SETUP button does nothing and has no explanation in the manual, also the manual says something about a TIME menu after holding down the SOUND button but that doesn't exist either on my radio. Care to comment on these two issues?
2003 Wildcat 27RL
2008 Toyota Tundra 5.7L Crewmax
Superglide 3100 Autoslider Hitch
Timbren SES
Prodigy P3 brake controller
flyguy is offline   Reply With Quote
concertone
