Old 07-14-2013, 03:05 PM   #1
Concertone not working
I have a Concertone dvd player in my 2009 Rockwood ultra lite 8306SS. On my way down to Myrtle Beach it quick working. No power to it, checked fuses at fuse panel. Pounded on it and still not working . Any ideas??? Everything else in camper works including TV. It is not the GFI either, checked it.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 07-14-2013, 03:18 PM   #2
Herk7769's Avatar
There is an inline fuse behind the unit.
Color me curious, why did you think that pounding on it would fix it?
HAM CALLSIGN - KC3FFW
Old 07-14-2013, 03:31 PM   #3
Just checking if it was something loose. It was more of a tap, pounding was what I wanted to do.
How can i remove to check fuse? I didn't see any opening like a slot to stick a screwdriver in.
Old 07-14-2013, 03:37 PM   #4
Sorry for my bad manners Herk, thank you for responding!
Old 07-14-2013, 05:42 PM   #5
Herk7769's Avatar
No bad manners at all!
That was me just trying to be funny (and failing miserably).
Look at the bottom of the unit, there are 2 slots for a flat bladed screw driver.
CAREFULLY insert the screw driver and twist; the cover at that corner should pop. Continue carefully lifting around the 4 corners until the faceplate pops off and you will see the 4 mounting screws.
Concertone® FAQs
Old 07-14-2013, 09:27 PM   #6
Thanks again, I will look at it tomorrow
Old 07-14-2013, 10:02 PM   #7
Wolfpacduramaxman
My 2009 Wolf Pac 16 DFWP has the same Concertone unit. The alarm clock kept going off at 2 am. I went on the web and found an owners manual (PDF). I also found several post regarding multiple problems with these units. Mine was junk-could not shut off the alarm and it could not be repaired. I was fortunate and found one (new)on Forest River Forums. Best of luck. Googmiester
Wolfpac Duramax
googmiester is offline   Reply With Quote
Old 07-14-2013, 10:36 PM   #8
Missing Link
cyclepuck's Avatar
Mine quit this spring and after researching a little I pulled the fuse out for a minute or two then put it back in. Started right up basically resetting it.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 07-15-2013, 06:01 AM   #9
If your talking about the fuse for the radio at the breaker panel, I tried that also but no luck. Thank you.
Old 07-15-2013, 06:49 AM   #10
Herk7769's Avatar
There is a blade fuse in the back of the radio.
