Old 06-05-2016, 06:40 PM   #1
Cyber Phrenologist
Radio's Avatar
Concertone Removal without messing up
Saw some posts asking about this sort of thing. I suspect all Concertone are similar to mine. Jensen and iRV probably pretty much the same.
There are two tiny slots located on the bottom of the trim piece. The slots are very small. Insert a thin screwdriver to start removing the trim. NOTE! The plastic trim that touches the wood cabinet will remain in place for now. Don't pry between the plastic and the wood!
Remove the trim with your fingers
This will reveal 10 screw holes. Usually not all of them will have screws installed. Remove the screws and the unit slides right out.
The wiring is bundled into groups with connectors. You will need to have a way to keep the RVs wires from falling down inside the cabinet, like tying them off with string.
Be sure to reinstall the trim with the slots on the bottom.
ID:	110230   Click image for larger version
ID:	110231   Click image for larger version
ID:	110232   Click image for larger version
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
concertone
