Old 08-08-2011, 09:17 PM   #11
acadianbob's Avatar
Jensen AWM970 Installed, Pictures
The Jensen is a very nice unit.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 08-09-2011, 06:15 AM   #12
Nights Camped in 2010 - 2
Bob, saw your install and that helped me decide to dump the Concertone. I got mine from American Trailer Supply out of Elkhart. I later found one on eBay for less, but I am leery of electronics on eBay....just me. Plus, Bruce is sending a remote control storage pocket that should fill the gap due to the smaller height of the Jensen. Not sure if I will use it or not, but will see how it looks roughed in then decide. I will post pictures when I am finished. Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 08-10-2011, 03:03 PM   #13
Originally Posted by sailingsuppo46 View Post
Kirk,
Thanks. I was thinking the same thing. No use for the trigger wire, so I would cap it off and tape it. Appreciate the info on the ground. I will connect as you stated and see how things go. I should get the unit on Thursday and have it installed by the weekend. We are heading out for a week on Sunday, so it would be nice to have it in and tested before heading out. Thanks again.
Hope it all works out for ya' !
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 08-11-2011, 08:22 AM   #14
Thanks. Unit arrives today. Hope to have it in tonight.
George Kelly
Old 08-11-2011, 11:27 AM   #15
acadianbob's Avatar
You will be amazed at the improvement in sound. Let us know how you like it.
Old 08-11-2011, 01:23 PM   #16
firedude01's Avatar
on my 3rd it and this one is working ok for now any way knock on wood
firedude01 is offline   Reply With Quote
Old 08-12-2011, 08:14 PM   #17
All,
Got the Jensen last night and installed this afternoon. Wow, what a difference. Install was pretty easy. Sound great. Glad I switched. Thanks for all the information and help.
George Kelly
Old 08-12-2011, 08:26 PM   #18
acadianbob's Avatar
All,
Awesome! Yeah, the difference is HUGE! Glad you like it.
Old 08-12-2011, 08:28 PM   #19
acadianbob's Avatar
Bruce is sending a remote control storage pocket that should fill the gap due to the smaller height of the Jensen. Not sure if I will use it or not, but will see how it looks roughed in then decide.,
I left a small gap top and bottom for cooling . . .
Old 08-12-2011, 10:51 PM   #20
If you typically run on battery power, you may want to add a switch in series with the ignition wire. Automotive radios will draw a considerable drain on your battery even with the radio switch in the off position (mine was .28 amps, .02 amps with ignition switched off). The direct connect will keep your memory settings.
eorcstahl is offline   Reply With Quote
