Old 06-09-2008, 09:49 PM   #1
gillguy's Avatar
Concertone static/pop noise
I know there are a lot of complaints about the Concertone and I've had my share. I'm on my 3rd -4th can't keep track of them anymore. Any way I wanted to post this as a separate thread, even though there are complaints in other post concerning the same thing. Or at least close to it. On my newest unit it worked great the first time out, then the next trip it started making a steady popping noise, not very loud, but annoying. You could turn up the volume to drown it out, but it was still there.
Since my TT is out of warranty and FR doesn't want to help anymore I pulled the unit back out to start checking wires. I wasn't crazy about the wire ties , one had come off, so I bought some Euro style terminal strips to connect the wires and replace all the wire ties, all 22 of them. Once this was done I reconnected the unit and discovered the popping noise had decreased, so I figured it had to be a ground issue. I pulled the 15AMP fuse for the TV and the noise was gone. Then I connected a long wire to the TT frame so knew I had a good ground then temp connected it to the ground wires in the terminal strip. Noise went away. Now I had to find a good ground inside the cabinet area behind the Concertone. Ended up dropping a length of wire down inside the wall and fishing it over to the bottom cabinet and securing it to an aluminum stud.
Hope this helps anyone with this type of noise problem.
Lets see if I can add a few pics.
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
gillguy is offline   Reply With Quote
Old 06-10-2008, 05:24 AM   #2
KyDan's Avatar
Good post, thanks for the info and pictures!
I thought you were hot on the trail of my problem but I have
Morse code beep, beep, beep in the background when I watch
a DVD movie.
Also constant hiss when listening to music CDs as well as FM radio.
I just sent my 2nd one back last evening.
On a similar note-- when I was re-arranging my tongue mounted
LP tanks and battery boxes I found they had simply fastened
the 12v ground wire under the screw that mounts the emergency
breakaway switch. It wasn't even all that tight and there was already
some rust under it!!
I ran a dedicated #8 ground wire from the batteries all the way back
to the power center and landed it on the ground/neutral buss.
Cleaning up that wire mess behind my Concertone is next on my list!!
Peace!
Dan & Rita D
Old 06-10-2008, 06:39 AM   #3
gillguy's Avatar
Dan
Do you have XM? If so disconnect it and it should solve your hiss.
Old 06-10-2008, 07:11 AM   #4
KyDan's Avatar
Originally Posted by gillguy View Post
Dan
I wish it was that easy. We don't have XM radio but I want one!
Also, our first Concertone was just loud. Even on volume level 1 it
was too loud in the "bedroom" when watching a DVD.
THIS one starts out OK and gets louder as we watch.
Last time we watched a movie I had to turn it down 3 times
before the movie was over- volume number didn't
change but it just got louder and louder.... sheesh they are crap.
This is the ONE big thing that keeps us from being totally satisfied
customers.
It feels like Forest River just doesn't care whether they work or not.
Old 06-16-2008, 01:07 PM   #5
Hello,
What amp trip did you use?
jeffreysee is offline   Reply With Quote
Old 06-16-2008, 01:19 PM   #6
KyDan's Avatar
Originally Posted by jeffreysee View Post
Hello,
What???
Old 06-16-2008, 03:11 PM   #7
My bad. Too eager to reply. I wanted to know what amp load his terminal strips were rated at.
Old 06-18-2008, 09:55 PM   #8
Dodge Guy's Avatar
Here is my fix for the Concerthole!
I had my neighbor make me a wood panel to cover up the existing hole and I installed a JVC car stereo with remote and front aux. input (for the DVD surround). I installed an extra amp I had to run the subwoofers in the ceiling. the sound is not even compareable to the Concertone!
I installed these push on/off switches to turn off and on the outside speakers and the inside rear speakers. I just fade the radio to the rear, the outside speakers are wired in with the rear speakers then I can just turn off the inside rears and turn on the outside speakers.
I have approx. $110 invested in this if I had to by the amp figure another $50
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-30-2008, 01:11 PM   #9
OK...the Jensen AWM970 unit is available ONLY through ASA Electronics distributors (Kingston Sales, (866-733-2820)). They are getting $199 for it.
