Old 08-28-2012, 11:55 AM   #91
Md Jeff's Avatar
I am technically challenged and have a question about my GT-3 and the HDMI hook-up to my tv; I bought a cable and plan to install it, do I need to disconnect the present a/v cables running between the GT-3 and my tv AND what are the implications of using the HDMI cable and still getting the audio signal from my to tv to the surround sound?
Md Jeff is offline   Reply With Quote
Old 08-28-2012, 12:03 PM   #92
DAISY BOYKIN's Avatar
A/V connectors----------------
I left the A/V connections connected, added HDMI cable, GT-3 works great.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
BOLIY PRO 3600SI GEN
DAYS CAMPED 2016 74 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 08-28-2012, 12:09 PM   #93
Road-King's Avatar
The HDMI hook-up on the back of the GT-3 is an out jack. It will send digital video and audio from the GT-3 to your TV. So in my case it only sends a signal when I use the DVD player.
I did and I suggest you leave the existing RCA cables hooked up so if your watching regular TV or hook up something else to your TV(Blu-Ray, game system, etc.) you could use your surround sound system. You need the RCA's from the TV audio "OUT" to the GT-3 audio "IN" for this to work.
It's been awhile since I looked at the back of the TV, I think you could remove the RCA's from the OUT on the GT-3 to the video IN on the TV. But I just left them there. I doesn't hurt anything...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-28-2012, 01:38 PM   #94
Md Jeff's Avatar
Thanks for the info, that's what I needed to know easier to leave them hooked up than it is to re-install them
Old 10-13-2012, 05:35 PM   #95
RalphieAdie's Avatar
We just took delivery of our Rockwood 8244WS 2013, with a Genesis 3. I've gotten the surround sound to work in the unit; the dvd player is working fine; blue tooth working great also. Just not sure how to add a game system to the mix. The unit has extensive RCA input jacks pre-wired and a switch to designate which bank of RCA input jacks are to be used. When I connect my game to the RCA input jacks and select the "game switch", I'm don't know what to select on the Genesis or the tv in order to make the connection work. I believe I've attempted every obvious combination on the tv menu and on the Genesis input side...HELP!
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 10-13-2012, 06:00 PM   #96
Herk7769's Avatar
Make sure the cable from your wall plate did not become disconnected from the rear of the radio.
HAM CALLSIGN - KC3FFW
Old 10-13-2012, 06:02 PM   #97
I will check tomorrow morning. We have storms approaching, so the slider is in at the moment. Thanks for your help.
Ralph & Adrienne
Old 10-13-2012, 06:48 PM   #98
Herk7769's Avatar
It should also tell you what channel on the radio the plate is connected to.
Old 10-14-2012, 04:14 PM   #99
It appears that everything is connected correctly. I have selected the "game" on the slider switch. What mode do I need to select on the Genesis...AU1, ETC? Then I will need to select a mode on the television. Lots of decisions to make without any real guides.
Thanks for the help.
Ralph & Adrienne
Old 10-14-2012, 05:04 PM   #100
Herk7769's Avatar
You said you checked the cables. The cables behind the radio are marked with the input they work. Set the radio to the input marked on your cables.
If for some reason your cables are not marked; if you have a concertone, the pin out looks like this:
led pad
