Old 08-02-2013, 08:05 AM   #141
Originally Posted by herk7769 View Post
Try a "CTRL-ALT-DLT" and reboot it.
Remove ALL power (including the battery ground wire) for 1 minute and reapply power to the trailer. That will restart the computer that runs the radio.
This is far easier than removing the radio from the wall to access the fuse behind it. Too easy to break the front bezel.
I tried the fuse but will try this this evening, Thank you. If this does not work guess I will have to break down and get the zx800. But wow, Expensive fix.
pcmdnh is offline   Reply With Quote
Old 08-02-2013, 08:32 AM   #142
Herk7769's Avatar
There is more than one fuse for this unit.
I have no idea where the "second fuse" is for mine (behind the power center I think).
HAM CALLSIGN - KC3FFW
Old 08-02-2013, 08:35 AM   #143
Really? Didnt know about the 2nd fuse. Thank you
Old 08-02-2013, 09:02 AM   #144
CANADA FROG RALLY 2017
B and B's Avatar
Originally Posted by BMWPilot View Post
I decided to see if I could get actual surround sound so I added the optical cable between my TV to the 3.0. It really does not sound good. I was picking up hiss and digital noise. I ruled out the electrical in the trailer by making sure all appliances and lights were turned off. I tried it both at a campground electric service and at home. Still the same noise. So, in trying to figure out if it was the TV or Radio I connected the optical to a media player. This has noise as well. Mostly some his and a few digital data pops when the player seeks info from the memory. card.
Is this radio just overly sensitive on the optical input or is this the norm? If I take it to the dealer who may not be as in tune with what audio should sound like he would probably say I am getting sound out of it so not much he can do.
The Stereo input is crystal clear, no noise, just no surround....
Any ideas?
I have tried the same thing, same problem. I am going to try a optical to coax convertor from my Toshiba TV to the GT 3.0 to see if this works. The noise you are hearing appears to be a digital frequency error, clock rate related.
I was actually working on this last night on my new per. Will update once I check the other option.
Brian
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 08-02-2013, 09:04 AM   #145
B and B's Avatar
There is 2 fuses. One for memory use, keeps stations and settings, second one is for the actual system to use for the amplifiers etc.
B
B and B
Old 08-02-2013, 09:07 AM   #146
B and B's Avatar
Here is a link to another forum with Bob Fields as well. Hopefuly some questions could be answered here as well regarding these units.
Genesis Technologies presence on the Heartland Owners Forum
B and B
Old 08-02-2013, 11:07 AM   #147
Road-King's Avatar
Brian
I installed a optical cable from mt Toshiba TV to the GT 3.0. Sometimes it works, sometimes it don't. Let me know if you have better luck and we can compare settings on the TV and GT 3.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-03-2013, 07:51 PM   #148
Brian
I was actually thinking of trying the same thing but haven't had the trailer back home from the storage lot to tinker with it. Looking forward to hear if you have any success. Sounds like getting a replacement radio won't make any difference if you are having the same issue.
2013 Rockwood 8329ss
2006 Dodge Ram 1500 Quad Cab SLT 4x2 5.7L
BMWPilot is offline   Reply With Quote
Old 08-05-2013, 10:02 AM   #149
B
Well removing power both DC and AC didnt work and sent email and phone call to Bob but have had no luck.
Old 09-05-2013, 07:23 AM   #150
KyDan's Avatar
EDIT- Sept 9, 2013
Bob Fields is no longer working for Concertone.
We do not have a Concertone rep monitoring the FRF site as far as we know.
Concertone e-mail address is
SUPPORT@CONCERTONE.COM
Good Luck!
led pad
