Old 05-19-2014, 06:40 PM   #161
brownie289's Avatar
Hard reset worked!
Pulled power off and waited a few and presto it worked
2015-26days, 2014-32days,
2013-33days, 2012-30days
brownie289 is offline   Reply With Quote
Old 05-21-2014, 02:12 PM   #162
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Check all your grounds - especially at the battery and converter. Then disconnect ZX75 completely from power for 30 seconds and try again.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 05-21-2014, 02:21 PM   #163
brownie289's Avatar
I pulled the unit off the wall and removed the power, it stayed lit up for a couple min then went dead.
Plugged it back in and works fine.
Your way sounds easier!
Old 05-21-2014, 03:02 PM   #164
Barney1's Avatar
Bob you are back!!!!!
Yeah!
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 05-21-2014, 03:31 PM   #165
Owner - RVtronics
Bob Fields's Avatar
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Old 05-26-2014, 04:27 PM   #166
Concertone and Winegard
I have a 2007 Forest River Cardinal fifth wheel. It has a 5.1 Concertone surround sound with a Windgard Select system box in the cabinet.
When I purchased it it had a smaller TV that did not work. The rep at the Camping World said it was an anolog TV. They purchased a small digital box and the TV worked fine on antenna but I could not get it to work on cable.
Later I replaced the TV altogether with a digital TV and took away the box they had given me as a digital converter. There is a cable connection and a yellow pin jack. I connected both to my TV.
My TV works fine on Antenna and usually finds many stations; however, it is only using the TVís speakers. When I try to use cable it does not ever find any stations at all. I turn off the antenna boost when trying cable but it does not find any stations.
Could anyone help me with how to set it up to use the surroundsound speakers when watching TV and how I could get cable? i did also send this email to the email in the string for Concertone. No reply so far but i just sent it.
Genghis is offline   Reply With Quote
Old 05-27-2014, 07:11 AM   #167
Owner - RVtronics
Bob Fields's Avatar
Genghis, your 2007 surround sound system has audio INPUTS that you may be able to utilize IF your TV has RCA audio OUTPUTS. Some time new tv's do not.
You can go here: Concertoneģ Product Gallery to find your radio and manual.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Old 05-27-2014, 07:18 AM   #168
Herk7769's Avatar
If your TV has digital outputs you can get true surround sound from OTA broadcasts with your Genesis using the digital inputs in the rear.
HAM CALLSIGN - KC3FFW
Old 05-27-2014, 07:34 AM   #169
KyDan's Avatar
Can't help you on surround sound issues but my 2008 trailer has this
winegard wall plate (see photo below).
I have to switch my TV cable from the "amplified" output with
the lighted button to the Aux/sat connection when I'm hooked up to
cable at the camp ground.
Try that and see if you get your cable stations when you scan next time.
Good luck!
Peace!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-44, 2017-36
Old 05-27-2014, 07:39 AM   #170
KyDan's Avatar
Oh yeah, I use an earphone to RCA plug adapter cable to plug into the
earphone jack on my TV and run that to a game input on my sound system.
It's not 5 channel "surround sound" but it sounds fine and I get sound out
of all my speakers and we can hear the TV when the AC is running!
led pad
