Old 10-20-2009, 08:59 AM   #1
Wolfpack
Send a message via Yahoo to iamoilcan
Concertone TV wont Power up!
Power works to the control panel for my concertone.. however in the TV mode I get no power to my 20" flat screen.. looking for fuses and other solutions? Help me!, Also batteries will not convert when the generator is turned off.. no power to anything in the trailer with either batteries or hooked to my truck power. Only Outside marker and break lights work..
iamoilcan is offline   Reply With Quote
Old 10-20-2009, 02:29 PM   #2
On problem 1, the TV has it's own remote that you have to use to turn it on. The only thing that the Concertone ZX600 does, and I'm guessing that's your model, is control the sound via the speakers from the Concertone. Also AV functions picture (DVD) is viewed thru the TV, but like I said, it's controlled by its own remote. Hope this helps you!! Randy
Old 10-21-2009, 10:30 AM   #3
Wolfpack
Larger than 20" Flat Screen?
Thanks for the heads up on the remote.. I tried it with new batteries a couple of days ago.. when ALL MY POWER was out.. Got the power issue resolved.. was a loose connection below my batteries on the outside next to the frame.. My electrical guy said that any loose connection between the battery and the converter usually keeps the entire system down... the connections need to be tight all the time..
Anyway.. I will try the external remote.. however, when the TV did work.. just cycling thru from Radio to CD to DVD etc.. the TV powered up when the TV selection was activated.
What if I wanted to have a larger than 20" flat screen.. any ideas how large a wall mount can be with the concertone mounting system?
