Old 07-16-2013, 06:56 PM   #1
Concertone ZX100 clock works, unit doesn't
Has anyone else experienced this? I have been reading through the forums and have not run across it so I apologize if it has been posted before and a solution given.
Here are the details.
The unit worked on the first two trips we took but on the third trip would not power on. The clock works, though I have not tried setting it, but the unit itself will not power on and shows no signs of life.
I pulled the unit and checked to see if the fuse was blown. It was not, I tested it, but I went ahead and replaced it just to be safe.
Same problem.
So.....has anyone seen this or have any ideas as to what it could be? I honestly wouldn't have been messing with it were it not for my wife complaining that it still isn't working and we are about to take a 3 week trip.
Also, if the unit needs to be replaced what are the best/easiest options that won't require some custom install or reworking of the wiring?
Thanks for your time!
shiner is offline   Reply With Quote
Old 07-16-2013, 08:24 PM   #2
bikendan's Avatar
that's what we have.
not many other companies make one that will fit in the same size hole, other than Concertone.
most other brands make ones that shorter and wider, so it would require some modifications.
Equalizer WDH
