Old 05-23-2013, 08:21 PM   #1
Concertone zx500 not powering up
Bob,
Please help me diagnose a radio that red light is on but will not power up.
I recently purchased a 2006 Forest River Cardinal fifth wheel and the conncertone ZX500 (pretty sure) wasn't working so I am not at all familiar with this system. Please direct me in the correct steps to check this unit to see if it could be something simple. Thanks very much Mr. Fields.
Sherrytcombs is offline   Reply With Quote
Old 05-23-2013, 08:48 PM   #2
Herk7769's Avatar
I am sure Mr. Fields will be by fairly soon. Until he does, here are some things to try and the manual if you need it.
Remove all power from the radio (easiest is to unplug shore power and remove the ground wire from the battery for one minute), then reconnect the battery cable and the shore power.
This should reset the radio and clear any errors.
HAM CALLSIGN - KC3FFW
Old 05-23-2013, 09:40 PM   #3
Thanks so much, I will definitely try that. I have taken the fuse out and put back, but no luck. I will get back to you as how your suggestion goes, I may need help with doing that as well. Thanks again.
Old 05-30-2013, 07:09 PM   #4
Concertone ZX500
I have identified that I have the concertone zx500. I also found 4 wires that are crimped. the are tan and tan & black wires. Could that be an issue. I cannot find were these would go. I just bought this rv and am very unfamiliar with the system. Please help if you can. I have taken the fuse out and I still have the red light but no power. Any help would be greatly appreciated.
Old 05-30-2013, 07:18 PM   #5
Herk7769's Avatar
Hope this manual helps.
Old 05-30-2013, 07:36 PM   #6
Manual
thanks so much for your help. I have looked at the manual but i quess I am just dumb. I know nothing about wiring. Can you just kinda help me trouble shoot some things and maybe walk me thru some steps to test
Old 05-30-2013, 08:14 PM   #7
Herk7769's Avatar
I would try a hard reset first.
Turn off everything in the camper you can; lights fridge; AC; etc
Remove ALL power from the camper.
Open the main circuit breaker in the power center (or turn it off at the pole).
Remove the GROUND wire from the camper's storage battery.
No lights should be on at the radio. (Power button etc)
WAIT 1 full minute (or more).
Reconnect the GROUND wire on the battery FIRST. Might be some light sparking so be prepared for that. That is why you turn as much off before hand as you can.
Then go inside and try the radio. If it works you are done.
If not, it might be bad.
Turn the main breaker on and make sure you don't forget to turn the fridge back on.
Old 05-30-2013, 08:43 PM   #8
Thank you so much, I will definitely try that asap. I appreciate everything you are doing for me. I will let you know how that goes. Thanks again.
Old 05-30-2013, 08:50 PM   #9
Herk7769's Avatar
There is an different way to do it if you are handy with a screwdriver and not afraid to break the radio getting it off the wall. There are two fuses back there somewhere (a always on direct to the battery for the clock and permanent memory and one on the radio fuse).
Finding them is the trick. My way is easier.
Old 05-30-2013, 09:25 PM   #10
QCCowboy's Avatar
Follow Herk's advice......
Concertone ZX600 - Power light red, but will not come on
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
