Old 07-19-2011, 12:50 AM   #1
Concertone ZX600 has no power
This is my first post on this forum. The ZX600 is 4 years old in our 2008 Wind Jammer. It was working fine until now. Its power button doesn't not lighten up to indicate it is on. I was going to play the DVD. How do I get this fix? The fuse in the breaker is good.
Thank you.
campgal is offline   Reply With Quote
Old 07-19-2011, 04:18 AM   #2
try pulling the fuse and putting it back in sometimes that works kinda reboots it
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 07-19-2011, 07:30 AM   #3
I believe that there is also a fuse wired into the back of the unit. You will need to remove the unit from the wall (or wherever it is mounted) and check that fuse as well.
Other than that, I have no other suggestions for you. Sorry.
Larry
2004 Toyota Tundra Double Cab
2010 Rockwood 2701SS
Killman is offline   Reply With Quote
Old 07-19-2011, 08:11 AM   #4
realebill's Avatar
i think there is a way to reset the unit, but i'm not at my trailer so i can't check my concerttone manual. check with Bob Fields at Concerttone. he should be able to give you some info.
bfields@concertone.com
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 07-19-2011, 08:18 AM   #5
Wanna Be Camper
SaskCampers's Avatar
Or just disconnect your main battery for 10 min or so, of course make sure you are not hooked to shore power. Easier than pulling the unit out of the wall to unplug it.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-19-2011, 11:21 PM   #6
just pull the fuse in the fuse box not really that hard to do
Old 07-26-2011, 10:20 AM   #7
Thank you.
The same thing happened with our ZX700, if the ZX600 is the same, in your Concertone owners manual there is a reset procedure. Can't remember right off which button(s) to press, but it is really quite simple. Once you find out which is the correct button, just press and hold for 10 seconds and the unit will reset to factory defaults. I will check my manual later and come back with the button info if it is still required.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 07-28-2011, 10:00 AM   #8
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
The ZX600 does NOT have the reset feature of the ZX700. The reset feature resets the factory system defaults. Disconnecting and reconecting the power is for a "reboot" and in older models, resets the factory dfaults as well.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
