Old 06-11-2012, 11:34 AM   #11
Originally Posted by amxpress View Post
If you don't get the answer you want on the forum, I have a brand new in the box never been used factory QC tested ZX 600 that I do not need. PM me if you're interested.
Do you still have the ZX600, if so how much are you asking for it?
rvice1 is offline   Reply With Quote
Old 06-11-2012, 12:37 PM   #12
Dallas Texas
TexasBBQ's Avatar
Originally Posted by Bob Fields View Post
Try pulling the fuse to reset...
I've got exactly the saem issue as lilfelr, the red LED lights up but nothing else. Pressed every button and nothing.
When you say pull the fuse are you refering to the one on the curcuit breaker panel or on the power cord of the Concertone?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 06-12-2012, 01:42 PM   #13
Make that a third one doing the same thing
Went into the trailer this weekend and same thing is happening to us Red light is on but nothing else will work or display. I will try and look for that factory reset and check the fuse and let you know.
Any other suggestions that I might need to check.
Michelle
love2rvcamp is offline   Reply With Quote
Old 06-12-2012, 01:48 PM   #14
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Pull the fuse behind the radio or the one in the fuse panel if one is labeled RADIO. Be sure the red light goes out for a minute then plug back in and try again.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 06-12-2012, 03:32 PM   #15
that worked for ours, DH went pulled out the fuse and reset. It is working again. Thanks for the help.
Michelle
