Old 04-25-2011, 09:52 AM   #1
Concertone ZX700
I just got in my 2012 8286WS and took it out for its maiden voyage this past weekend. While the kids were watching movies and I was switching back to AV2 for the regular TV audio to play through it, the unit would display FLASH when trying to select the different output mode. When it displays FLASH it would lock the unit up and when it finally went away it would always revert back to FM radio station. I was getting quite frustrated with it. Any ideas or similar problems.
mct800 is offline   Reply With Quote
Old 04-25-2011, 10:02 PM   #2
Mine stopped working all it replaced under warranty. Seems to be a common issue - search Concertone and you'll come up with all kinds of results.
Congrats on the new rig and happy camping!
Brian, Julia, Matthew (6), Patrick (4)
Ginger (Vizsla #1) & Bandit (Vizsla #2)
2010 Rockwood 8317SS Signature Ultralight
2005 Ford Excursion PSD - MBRP 4" Turbo back - Prodigy P3 - Dual Cam
2Vizslas is offline   Reply With Quote
Old 04-27-2011, 08:54 AM   #3
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Sorry for the frustration with you unit.
Please try resetting it by removing the fuse behind the unit for one minute. The radio has a processor (like a computer) and maybe its needs a reboot. You remove the radio by removing the trim ring (look at the bottom edge and you will see two small holes). Use a flat blade screw driver or strong butter knife to stick in there and pry off carefully and then removing the screws that hold it in. Now it wll come right out.
While you are in there, double check the wiring. You could have a bad ground ground or power connection...
Obviously if you unit continues to have an issue, have your selling dealer check it out.
Good luck and please let me know how it goes. My phone number is also below...
Bob Fields
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 05-13-2011, 01:53 PM   #4
Fire Instructor's Avatar
When mine acts up, I've typically corrected it by replacing the batteries on the remote! For some reason, mine goes haywire when the remote is underpowered, and I try to use it.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
