Old 10-28-2008, 10:22 AM   #11
Send a message via Yahoo to SSport
Originally Posted by KyDan View Post
It sounds like they've loaded the wrong software (alarm or sleep timer) into
some units with different hardware (remote without sleep/alarm button
and or LCD display without sleep/alarm wording).
In other words it's a total screw up and the factory should have jumped up
to replace those units without question.
Problem is, the odds of getting a good unit as a replacement don't seem
very good ;-((
lol, that's exactly why I just turn off the speakers after every use. I figure if that's the only problem I have....then I'm one of the lucky ones.....lol
SSport is offline   Reply With Quote
Old 03-17-2009, 02:27 PM   #12
Yep, I have the same problem. I use the speaker off trick too! It does get me once in a while though when I forget to turn off the speakers, problem is, its usually about 3am. Its really not a user friendly quality unit.
mckroo is offline   Reply With Quote
Old 05-18-2009, 09:46 PM   #13
Found the answer
Hi All,
I was told that with the unit powered off just press the XBASS button and the caption beep on appears. This toggles the alarm on and off.
cherokee_09_28A+ is offline   Reply With Quote
Old 06-08-2009, 08:49 PM   #14
pdq
pdq's Avatar
have the same problem - and most simple solution: turn off the speakers! (it works)
pdq
2008 rockwood 1809
s10
vancouver, bc
pdq is offline   Reply With Quote
Old 06-09-2009, 06:17 AM   #15
KyDan's Avatar
True but the alarm is still going off. You just can't hear it.
KyDan is online now   Reply With Quote
Old 08-21-2010, 01:50 PM   #16
dont feel to bad i got the same unit and it does the same thing try every thing still can not get the unite to turn oof i email the company to se what they got to say about it email is concertone.com
aweek1 is offline   Reply With Quote
Old 08-21-2010, 02:40 PM   #17
Herk7769's Avatar
Yes, the solution is here somewhere, but the answer is to remove power to the radio "completely" and then restore power.
Remove the fuse to the radio to do this.
This will disable the alarm.
Then NEVER use the alarm again.
It is a bug in the radio's programming and there is no "fix" according to the old post.
HAM CALLSIGN - KC3FFW
Old 08-21-2010, 03:01 PM   #18
Iggy's Avatar
I like the idea of shooting it using a 10 Guage shotgun with 00 Buck shot!
Old 08-21-2010, 03:03 PM   #19
Herk7769's Avatar
Dash Two
rockwood
