07-18-2014, 11:56 AM
Connect Ipad to rv to watch Netflix?
We have a rock wood signature light 2012 and have preciously connected to my iPad to watch netflix but can't remember how I did it. We have a genius technology gt-3.0. I have the cable connect to the slots under the tv. Can anyone help me out?
RossandJan
2012 Rockwood 8314BSS
2006 Chevy 2500 HD 6.0 gas 4x4
Ross - Letter Carrier (retired 2011), Jan - YNC(retired 1996)
Nights Camped 2011 (8)
07-18-2014, 01:09 PM
Dan
2014 Berkshire 390RB-60
07-18-2014, 06:53 PM
Thanks I have the manual, doesn't help.
RossandJan
07-18-2014, 07:24 PM
Wayne & Kim
I can't imagine how you did it without some sort of cable which has RCA connections. I know the GT-3.0 has Bluetooth capabilities but I think that is limited to music and phone (I used to enjoy that aspect of the Genesis in my TT I had; I have Bluetooth now but no phone support). But it looks like all the inputs are on the back. There is a USB port on front but not sure it will support iPad, though manual does mention playing video from USB source.
Have you considered an Apple TV? I took my old 2nd generation unit and keep it in the RV. HDMI to TV, and when I had the Genesis I also went optical audio to that to get even better sound. Then could use iPad Remote app if desired, but Netflix and many other options could go thru the Apple TV. Works pretty well for us.
Wayne and Kim
2014 Cedar Creek 36CKTS
2011 Ford F250 King Ranch 4x2 Diesel, added springs
Nights camped: 2014 - 32; 2013 - 23
07-18-2014, 07:41 PM
I have iPad connected using a cable. But need to know settings for tv/genius to get it to play on tv. Thanks
RossandJan
07-18-2014, 07:47 PM
. This is located under the tv where I connect to.
RossandJan
07-18-2014, 08:31 PM
Wayne & Kim
From looking at ur pic, it looks like maybe the white slider in lower right needs to be in the second from top position (perhaps B; hard to read clearly). It looks like it is maybe on slot C.
From reviewing the manual and from my fuzzy memory, you have to put the GT in DVD mode so that you can use on-screen menu to adjust the Video Setup to choose an option other than DVD (page 16 of manual references this). I recall I had to play with it a bit to get TV audio to play thru the GT, after I had pulled the unit out and run audio cable from TV to the GT.
Wayne and Kim
07-18-2014, 08:34 PM
There's all kinds of ways to use your iOS device sharing a connection to netflix. I use a rokio and a bluray player in my trailer. If your television has wi-fi of course you can skip the middleman.
Sent from my iPad 6 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
07-18-2014, 09:12 PM
I have a Roku box in mine. Connects to the wifi at the campground, or i can connect to my phone.
07-19-2014, 12:13 AM
Doesn't it count against your data allowance when you connect to your phone? We have phone and MIFI service thru Verizon and if I use my Ipad3 to watch Netflix or Hulu, to watch a show, it uses up my data allowance. I've tried using the campground WIFI but response was way too slow.
07-19-2014, 04:39 AM
It does count against your data, but I have 10g, which is enough to watch it here and there. We don't watch tv much anyways. Campground wifi is hit and miss. Some have no wifi, or wont let the box connect to it. Some are also slow. I have been to some where it works just fine though.
07-19-2014, 05:57 AM
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-19-2014, 08:14 AM
To minimize data used, Netflix lets you set your preference for definition (low, medium, high, or auto) under account settings.
07-20-2014, 02:38 PM
Thanks for everyones suggestions. We finally got it to work this morning. Setting tv to video and the genius on av1. Couldn't connect directly to TV since it's mounted and didn't want to take it down. Thanks again
RossandJan
07-20-2014, 04:27 PM
Wayne & Kim
Ur welcome and glad you are back in business!
Wayne
Wayne and Kim
07-21-2014, 06:32 PM
What kind of connector do you use to connect your phone to the Roku? I have an IPhone 5 and would like to play Netflix thru my tv in the camper.
07-21-2014, 06:52 PM
Wayne & Kim
I can't comment on Roku,but if you are an Apple user I would suggest the Apple TV instead. Hooks up to TV via HDMI cable (also has optical digital audio out if your stereo supports it, though audio from TV will play to stereo if you have it hooked up that way), and many TVs have side in puts to make the connection easy. You can use your iPhone as a more advanced remote (though it comes with one anyhow). In addition to Netflix, you can do Airplay mirroring (so anything on phone can show up on the TV if desired), watch or listen to your iTunes purchases, You Tube, and much more. Plus you can take it home to use there, if you are not full timing. Can connect to wifi wirelessly or via Ethernet.
PM if u want to know much more about it. I get kinda pumped up in a nerdy way talking about the device, cuz it doesn't get enough love!
Wayne
Wayne and Kim
07-21-2014, 07:42 PM
Sorry if already solved. Didn't read all comments. My tablet and DW's smartphone will do it with micro HDMI to HDMI cable. From tablet to back of TV HDMI jack. You'll need strong WiFi to stream.
2018 Forester 3011 DS
07-21-2014, 08:10 PM
OK here is where I plead techno-help LOL How did you connect your Roku to your Genius?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
07-21-2014, 08:21 PM
I don't use a connector. I share the internet connection on the iPhone and then connect to that wifi on the roku. A roku works just fine and can do HDMI also. Roku also has apps you can install to do many other things. He'll even a few simple games.
As a far as listening to anything on the iPhone/IPad you can just use the rv built in stereo system with a jack or Bluetooth if it's a newer one. No reason to buy even more stuff if you already have what you need/want.
