Old 09-22-2010, 07:26 AM   #1
connection diagram for RV2004D Concertone HELP!
2005 Wildcat -- what cable goes where?? I have RV2004D Concertone; no hookup instructions. I have Directv receiver (and have converter box if that is necessary). I want to get TV to play through the speakers of the Concertone system. I have only the main living room TV. All I can get to work on Concertone is the radio. Can anyone give me a diagram or clear hookup instructions. Thanks. (Also what works the outdoor speakers???)
dayz is offline   Reply With Quote
Old 09-22-2010, 03:10 PM   #2
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
The wiring diagram should be a label on the unit that you can see when you pull it out.
Do you need a manual?
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 09-22-2010, 03:35 PM   #3
connection diagram for RV2000D concertone
Thanks, I have the manual. What I need is not the wiring diagram but information on how to hook the TV / satellite cables to the "ins" on the wall plaques. The manual tells what to do AFTER you hook up; nothing tells you HOW to connect the cables from TV/VCR/Satellite receiver and/or the analog/digital converter box. (I have only the main living room TV.)
Old 11-26-2010, 01:38 PM   #4
OK, hook red to red, white to white, and yellow to yellow. That gives you left and right adio and (Yellow) video) Then when you turn on the concertone, click over to Aux one or two for TV feed. also use aux one or two on the tv menu to coordinate the two. Should work. Just punch buttons until you find the channel.
hankpac is offline   Reply With Quote
wildcat
