Old 03-16-2012, 01:20 PM   #1
Converter interferring with AM band on radio
Hi All,
New owner of a Vibe 6501, the converter (we've had this brand before) WFCO WF-8955 is interferes with the am radio band to the point that the stations are totally static. Has anyone had this problem before?
Thanks,
Ozkamper
ozkamper is offline   Reply With Quote
Old 03-16-2012, 01:37 PM   #2
TURBS's Avatar
Best bet is to buy a radio suppressor from radio shack
it may not solve it but will most likely help.
Old 03-16-2012, 04:49 PM   #3
might want to check on the antenna, we had same problem and dealer moved the antenna works much better now.
TDewy is offline   Reply With Quote
Old 03-17-2012, 08:42 AM   #4
terry.e's Avatar
Ailing Converter
Hi,
My radio would work for 20 to 30 minutes then it would start with the static, talked to a electonic repair guy and he said that the radio was getting "dirty power". Took converter out of trailer to the the electronic shop and they found a bad capacitor. Problem fixed!!
Terry
terry.e is offline   Reply With Quote
Old 03-21-2012, 07:04 AM   #5
I found the antenna of my concertone rolled up and tied behind the unit while trying to resolve other issues.
Don't know about which unit you have.
good luck
Ed
edgmills is offline   Reply With Quote
