Old 10-05-2014, 06:29 PM   #1
R&J Silverback's Avatar
Converter question
Just got home from a great weekend on the Washington coast. when we opened the unit up I saw there was no power in the unit.12 volt. battery checks full charge . all works ok when plug into 120v any suggestions on were to start??new 2014 silverback
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 10-05-2014, 07:01 PM   #2
VinceU's Avatar
There's normally a resettable fuse or circuit breaker on the + or red line close to the battery, often on the frame. Look for a popped button and push to reset. Even better to follow the circuit with a multimeter and trace the voltage back, battery to circuit panel. This should be the only interruption on the way. This assumes you have kept the battery disconnect switch closed. Do slides or jacks work. They have independent power connections at the battery.
Old 10-05-2014, 07:27 PM   #3
slides and level-up work fine. will go look for a reset switch, found a 30amp fuse and it was ok. has to be something simple. thank you
Old 10-06-2014, 04:35 AM   #4
Herk7769's Avatar
Look at the metal box your umbilical plugs into. Mine is under the pin box.
Right next to it is another resettable current limiter (under the red cover).
Make sure it did not pop (short side of limiter) and the terminals are not loose or corroded.
(On a travel trailer it is under the frame).
This limiter can pop if you routinely use the truck to open the slides and such with a low battery.
ID:	64175   Click image for larger version
ID:	64176   Click image for larger version
ID:	64177   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 10-09-2014, 04:41 PM   #5
thanks to Herk7769 my power is on all 12 volt is working. got to love this forum . thanks to all who try to help with posts and pics saves lots of time and MONEY
inverter
